Thread: Flat battery and immobiliser issues
  1. Flat battery and immobiliser issues
    Jul 2010
    Crosby UK
    Hi all, my wife recently acquired a Mk 3 Golf estate, and has been using it for a few weeks now. After returning from holiday, the battery was flat as a pancake. The problem is, the immobiliser will not turn itself off. The previous owner reckons it was factory fitted (think the car is a '97 model) and it has two plips on the unit, and a reference number of MPT 1340 on the back, and 'volkswagen' on the front. I have fitted a new battery to the plipper, but nothing changes. It is not an immobiliser with a 'key' part, just a rectangular unit. *Just found out it is a Scorpion 918 model*
    There is a push switch under the bonnet that shuts when you close the bonnet, and a siren. Inside the car there are three sensors on the dash, and a red light on the dash panel directly below the three heater controls, which is constantly on.
    Regardless of what I do, the hazards keep flashing, and the unit resets itself every minute or so.
    Any ideas on how to turn it off? The previous owner never used it, and had to dig out the plipper for me.
    All help gratefully received.
    Regards
    John
    Addendum - Ok, so after finally getting into the glovebox, as the handle had broken, i removed it and the lower parcel shelf. There was a flat unit, which I presume is the Scorpion unit. This has 3 connector blocks
    1 with about 10 connectors
    1 with about 7 connectors
    1 with a small 4 pin connector.
    I removed the 7 pin connector, and the immobiliser is now no more, and the engine starts fine :-).
    Now, what I need to find out is what the small 4 block connector is for, and whether there are any wires on the removed connector that should be left in!
    All lights, hazards, horn and radio work with this block out, so not really sure whether there is anything important on it.
    Last edited by Hotpants; 22-08-2010 at 07:29 PM. Reason: Grubbing around under glovebox
  2. Re: Flat battery and immobiliser issues
    Feb 2011
    Newmarket Suffolk
    Hi, You have a scorpion Imobiliser/alarm fitted, unfortunately when the battery goes flat the system memmory is lost & the equipment needed to reset it is obsolete, if you have a key fob with 2 buttons on it i can tell you how to dissable the system, check that you have a scorpion system & get back to me
  3. Re: Flat battery and immobiliser issues
    Jul 2010
    Crosby UK
    Quote Originally Posted by kevinjoybringer View Post
    Hi Kevin, thanks for the reply. I gave up in the end, removed the glovebox and took out the connector block from the wiring. At least it is quiet now!
    John
  4. Re: Flat battery and immobiliser issues
    Feb 2011
    Newmarket Suffolk
    You needed to join the yellow/red stripe & purple/black stripe wire together.
    That will get the engine started
  1. Please Help Immobiliser problem after Key fob battery change
    By mad4rovers in forum Alhambra
    Last Post: 28-08-2010, 01:44 PM
  2. Immobiliser Problem...i think
    By randomboy in forum Golf MK3 - 1993 - 1999
    Last Post: 14-03-2010, 10:15 PM
  3. HELP: Replaced battery now immobiliser keeps cutting in.
    By gazzoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2009, 12:43 PM
  4. About to disconnect battery on 2003 A6 1.9 TDI- immobiliser
    By paul b in forum Chat - Anything with wheels
    Last Post: 29-03-2008, 01:09 AM
  5. WARNING - Flat Battery?
    By sidatkins in forum Touran - Sharan - Caravelle
    Last Post: 28-03-2008, 05:58 PM
