Thread: Audi B6 Ambient Lighting Installation help.
  1. Audi B6 Ambient Lighting Installation help.
    Mar 2007
    Shropshire
    Hi people,
    I have been looking through eBay and have found a couple of simple ambient lighting packs on offer. They seem to be just a couple of LED's and a wire with a connector on each.
    Can anybody shed 'light' on this?
    Is it just a case of getting hold of a couple of LEDs, some wire and connectors and drilling a couple of holes in the roof light console?
    Any help would be much appreciated!
    -Desdesigner
    Apr 2007
    Hampshire
    Basically, and without beating about the bush, yes!! Would suggest a switch of some sort in case you dont want them on for whatever reason at some point rather than just hard wiring them into the light circuits.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    Mar 2007
    Shropshire
    Ahh, I see, interesting. Does anybody know the sort of connectors required/ wire connections needed?
    Many thanks
    -Desdesigner
    Oct 2005
    This is a common mod with the VW crew - it's known as the W8 dome light mod.
    Basically, the W8 Passat comes with these ambient downlights as standard. They easily fit Passat/Golf/Bora/Polo etc.
    See here for instructions, something tells me it's not quite as simple on the Audi though
    Foxy's W8 Dome Light mod
    Edit;
    Something similar on an A4
    Adding a Red Dome Light (Pre '99.5 models)
    Mar 2007
    Shropshire
    Hmmm, interesting again. I spose I could fit a rocker switch of some kind. If wired correctly, thses should come on with the side lights, correct?
    Many Thanks
    -Desdesigner
    Oct 2005
    That's right.
    If you also run a wire down to your dashlight rheostat you can have them dim and brighten as you adjust the brightness of your dashboard illumination.
  7. Re: Audi B6 Ambient Lighting Installation help.
    There is a Audi Part that can be retro fitted into the front reading light panel, Part Number 8E0919063A. It simply connects into the exisitng lighting circuit, only drawback is that you have drill two small holes in the panel. Check out this website for a installation guide:
    http://www.harddrive.plus.com/Docume...%20Install.pdf
  1. Bluetooth Installation
    By mackem in forum Chat - Anything with wheels
    Last Post: 20-11-2009, 07:23 PM
  2. Audi A4 1997 Aftermarket Alarm Installation
    By Marko Sparko in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2007, 04:13 PM
  3. Turbo installation
    By jamesmc1 in forum Passat - Archive Topics
    Last Post: 13-02-2007, 08:48 AM
  4. Lighting Up Time For New Audi R8
    Last Post: 25-12-2006, 07:42 PM
