Thread: 8e0 953 549 t
  1. 8e0 953 549 t
    Jun 2008
    chester
    hi all, can anyone tell me if this steering module supports cruise control please, have tried the looking up on internet can not find anythin with the letter T at the end of part number.
    cheers guys....
  2. Re: 8e0 953 549 t
    Sep 2009
    Apollo
    Edit again, I do have something for you this time. Based on several scans, it looks like that's a common Audi RS4 4.2L module. Several vehicles have the engine module coding for CCS enabled.
    I do wonder why it's only found in the RS4 and not any other models, or in this list: http://wiki.ross-tech.com/wiki/index...tting_%288E%29
  3. Re: 8e0 953 549 t
    Jun 2008
    chester
    Quote Originally Posted by Dana@Ross-Tech View Post
    hi, thanks for that, i have found out that it will link up with my b6 19tdi an the cruise will work just fine but the dis will not work off the stalk as the dis works off the rs4 steering wheel, (so i'v been told) if this is incorrect please let me know..so will need the wheel aswell as the module i think?..
    also when i start my car up from cold the cooling fan comes on an when it gets to temp it goes off, run a check its come up with a code 17664-p1256. checked the rosstech codes but my symptom is not on the problematic list. car runs fine just fan comes on in morning? any ideas..
    thanks for getting back to me, big help...
  4. Re: 8e0 953 549 t
    Norfolk
    17664 P1256 Engine Coolant Temp Sensor (G62), Open or Short to Plus
  5. Re: 8e0 953 549 t
    Sep 2009
    Apollo
    Quote Originally Posted by lee a4 View Post
    If this module is installed, please post the complete Auto-Scan.
  6. Re: 8e0 953 549 t
    swindon uk
    You are right, that control module is for RS4 and it will expect the dis buttons on the steering wheel. you will need a Q or R control module for dis to work on the wiper stalk.
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  1. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  2. Audi A4 2.0Tdi BLB wheel bearing housing right
    By Assari in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-02-2010, 10:53 PM
  3. cruise/dis retrofit programming help
    By jetbox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-12-2009, 07:12 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
