Thread: a4 quattro Gearbox /Torsen oil
Results 1 to 8 of 8
  1. a4 quattro Gearbox /Torsen oil
    May 2007
    Leeds
    Could anyone please help me choose the right oil to go into my 1.9tdi quattro manual gearbox. Gearbox code is DGW i think.
    I have been having some issues changing gears, so i changed the oil. I filled it up with GL5.
    Now I seem to have more issues putting it into second gear particularly when cold, but NOT always. I filled with 75W-90. I don't fully understand it. I have been reading that actually the OEM oil for the quattro has additives inside and that helps a lot. Audi charge about 15 pounds per liter or so.
    What shall I do, shall I go for OEM for both gearbox and rear diff, or shall I just add something like Molyslip or other additives that reduce friction and coat the surface. Please recommend me something from your experience and make a comparison if possible.
    My other worry i suppose is that I want to be sure that i don't affect anything in the way the torsen works, etc. I think I don't have any differential lock on any of the axis, it is all mechanical. The TOrsen diff gets its oil from the gerabox, doesn't it?
    ex Audi 1.9 TDI 1997, AHU
    Audi 1.8 Petrol/LPG
    Audi 1.9TDI AFN Quattro
  2. Re: a4 quattro Gearbox /Torsen oil
    Jun 2010
    england
    i have changed my gearbox oil twice in 2 weeks to cheapish 75w90 oil which have made the gearbox worse. I ordered redline mtl last night at £15 a liter.
  3. Re: a4 quattro Gearbox /Torsen oil
    May 2007
    Leeds
    I visited audi an hour ago. they seem to recommend exactly 75w-90 gearbox oil somewhere in their software for the DGW gearbox. However, they don't explicitly recommend that for the quattros in their software.
    What gearbox do you have carlover?
    I
    now seem to think that a smoother gearbox is down to the additives from the oil, which makes me consider buying some friction reducer and add to the oil.
    I have changed to GL5 not GL4. I also read somewhere that some additives inside GL5 may damage the synchros inside gearbox.
    I will either change to GL4 plus additives, or OEM..
    Any more opinions? Thanks
    Audi 1.8 Petrol/LPG
  4. Re: a4 quattro Gearbox /Torsen oil
    Jun 2010
    england
    buy genuine audi oil or redline mtl, that is what most people say for these old audi gearboxes.
  5. Re: a4 quattro Gearbox /Torsen oil
    Jun 2010
    england
    i changed my gearbox oil again today to redline mtl and the shifting is smooth as silk.
  6. Re: a4 quattro Gearbox /Torsen oil
    May 2007
    Leeds
    This may be useful to many others.
    I have actually checked the technical specs of various oils, not just what people describe. I think I managed to find out what OEM oil is for my car - I believe is a high spec Castrol.
    Both viscosities at 40 degrees and 100 degrees are lower than the Redline MT-90.
    What I have at the moment in my gearbox is Comma SX75W-90.
    Both, 40 degrees and 100 degrees viscosities are lower than Redline MT-90 for this oil. I can't see how replacing the oil with a slightly higher viscosity oil will help me...Am I wrong? My car clearly shifts better when warm particularly from 1-2gear.
    carlover, what oil did you put in first before changing to Redline MT-90? What car?
    I am very tempted to go for Redline MTL wich is 70w-80. I don't race, so hopefully it should be ok... What do you think?
    Audi 1.8 Petrol/LPG
  7. Re: a4 quattro Gearbox /Torsen oil
    Jun 2010
    england
    i used mtl.
    It now shifts better than the old genuine audi oil.
  8. Re: a4 quattro Gearbox /Torsen oil
    May 2007
    Leeds
    Sorry, I have just realised that you actually changed to MTL 70w-80! I mentioned Redline MT-90 because that is recommended as being 75w-90. If you are happy with yours, and a lower viscosity is still ok, I will definetely go for it.
    UPDATE:
    I have finally changed both differential oil and gearbox oil to Redline MTL 70w-80. I have not posted right away just to be sure that it's not placebo...
    My conclusion : It did make changing into 1st and 2nd, but particularly 2nd much easier. Third gear about the same I'd say, and 4th and 5th either the same, or maybe slightly worse. I may be talking nonsense here, but maybe friction is affected by viscosity in a different way for the different cog wheels. Overall it is a clear improvement because 4th and 5th are fairly easy to synchronize and you can give the synchro more thime to work.
    I am now very rarely getting a crunch in 2nd gear. Thanks for sharing the information with me.
    Audi 1.8 Petrol/LPG
  1. Basic Oil advice from Opie Oils
    By oilman in forum Chat - Completely Off Topic
    Last Post: 09-09-2009, 03:11 PM
  2. Identify oil leak after oil change
    By turbocharlie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2009, 01:56 AM
  3. '92 MkII 1.8 NO oil pressure
    By 2old2turbo in forum Golf MK2 - 1984 - 1992
    Last Post: 06-10-2007, 09:58 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
