Hi I'm new to this, I've just got hold of a 1997 a8 with a few problems to sort out on it. Most of the are no problem to do, things like cv joint etc. The one thing I've got a problem with is that the heaters are stuck on full heat. I've gone through all the flap motors and there ok. I think it the two climate control heat valves next to the blower motor in the engine bay. Has anyone ever pulled these apart a serviced them before.
Any he'll would be great
I'm also going to see if can fix the drivers arm rest, I'm going to machine a new square block for out of some ali bar and bolt it on, any one had any luck with fixing them so they look right and work again???
