Thread: Battery Drain
  1. Battery Drain
    Aug 2010
    Prestatyn
    Hi everyone...
    I have a Audi A4 b6 2003 2.0 TDI
    I love this car, it's been perfect for the 4 months that I've owned it, until, I went away for a week. When I returned my car wouldn't start, battery just didn't have enough in it. I got a friend to gget some jump leads on it and it fired up straight away...
    I took it for a drive to fill it back up and everything
    was fine.... Well until 4 days later when it wouldn't start again. I bit the bullet and nought a new battery, this gas been fine for another 4 days and then today, car started up then moved 5 metres and died !!!!
    Does anyone have any clue what can be doing this ? I've tested the alternator and it's charging at 14.8, I've checked the footwell and there us no water damage, and I've watched the hazard light and it doesn't flash.
    Please help
  2. Re: Battery Drain
    Jun 2008
    Mold
    Best thing would be to have the fault codes read with vag com, I can help out if you need your not far from me...
  3. Re: Battery Drain
    Aug 2010
    Prestatyn
    Hi Rich
    Thanks alot, that's really kind if you, but I wouldn't want you to go to any trouble.
    Do you know of any good garages locally that would be on the ball with faults like this ?
  4. Re: Battery Drain
    Jun 2008
    Mold
    Do you have the battery light up on the dash when it's running..?
  5. Re: Battery Drain
    Aug 2010
    Prestatyn
    Not a thing, everything is running as normal.
    When it died today it was that flat the stereo needs coding again.
  6. Re: Battery Drain
    Sep 2008
    chester
    17 Post(s)
    You need a auto electrician,could be the alternator discharging the battery.
  7. Re: Battery Drain
    Sep 2008
    Highlands
    12 Post(s)
    Hi INSKIP
    Did you resplve the problem?
    I have the same now with my 2002 1.9tdi
    Vin
  1. How To Remove battery without removing windscreen cowling & drain plenum, inc TDi
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2014, 03:03 PM
  2. Getting at the drain under the Passat battery
    By swampman in forum Volkswagen
    Last Post: 22-12-2009, 12:30 PM
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  5. passat tdi battery drain
    By andycampers in forum Passat - Archive Topics
    Last Post: 18-11-2007, 04:37 PM
