Thread: Power supply to aftermarket head unit.
Results 1 to 8 of 8
  1. Power supply to aftermarket head unit.
    Ardfern
    8 Post(s)
    I have just had a Sony DAB head unit fitted to my A4 1.9 tdi 2003 Avant.
    It works very well and I am relieved to be rid of the rubbishy FM crackles, however my audio fitter tells me that he cannot arrange the power supply so that the unit remains powered until the key is removed from the ignition.
    I have become used to that feature and miss it considerably.
    Does anyone know how that can be restored?
    Thanks for any help with this.
  2. Re: Power supp;y to aftermarket head unit.
    Aug 2010
    London
    Hi, do you mean that you would like your Sony head unit to remain on when the keys are out of the ignition?
    Online Car Audio
  3. Re: Power supp;y to aftermarket head unit.
    May 2008
    If you want it powered until the key is removed (like the OEM stereo does) then you need to add an adapter (CAN bus emulator)
  4. Re: Power supp;y to aftermarket head unit.
    Ardfern
    8 Post(s)
    Thanks both for those replies.
    Isaac, you are right to understand that I want the unit to remain on after the engine has stopped but NOT after the key is removed from the ignition.
    Where can I get a canbus emulator? Is it a straightforward fit? Do you have one?
    I have VCDS, if that is necessary for the set up.
  5. Re: Power supp;y to aftermarket head unit.
    Aug 2010
    London
    Dear Niall
    If you would like the new unit to be powered in the same way as the OEM then yes you will require a CAN interface, to be honest it would be best if you were to source and have this item fitted locally, as you had the head unit fitted professionally it would be best to have the CAN interface fitted the same way. If you speak to a local car audio dealer there are plenty of CAN interfaces on the market.
  6. Re: Power supp;y to aftermarket head unit.
    Ardfern
    8 Post(s)
    Thanks for that, however, I did ask my local audio tech. who fitted the H/U
    if he could achieve the power behaviour of the oem and he was not able to offer a solution.
    Do you think that you could supply the correct interface?
    The H/U is a Sony CDX-DAB6650.
    I assume that this is a common problem to which many here would
    welcome a solution.
    Many thanks.
  7. Re: Power supp;y to aftermarket head unit.
    Aug 2010
    London
    Hi Niall
    We would be able to supply a CAN interface, but to be honest as I said you would better sourcing it locally as you would need to have it installed anyway and I would imagine it would be much cheaper for you to get a supply and fit option at a local car audio dealer, they may have a certain brand that they are familiar with or prefer using.
  8. Re: Power supply to aftermarket head unit.
    Ardfern
    8 Post(s)
    Thanks for that.
    Anyone know a reliable audio tech in the West Midlands?
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Question How to install aftermarket head unit in T5 transporter?
    By Lemmiwinks in forum In Car Entertainment
    Last Post: 17-01-2010, 04:18 PM
  3. Ipod kit for rcd 300 ( caddy van )
    By h24nst in forum The Commercial Range
    Last Post: 16-05-2009, 09:50 AM
  4. Please Help After market head unit fuse keeps blowing.
    By tomo180 in forum Bora - 1998 - 2005
    Last Post: 21-05-2008, 09:39 PM
  5. Need Help Installing A Head Unit
    By Del75 in forum Chat - Completely Off Topic
    Last Post: 01-02-2007, 03:06 PM
