Thread: Multiple Electrical Failure
Results 1 to 10 of 10
  1. Multiple Electrical Failure
    ChillOut Guest
    Can anyone suggest a single cause for the following which have all stopped working at the same time:
    Climatronic - totally dead, no display
    Horn
    Steering Controls for radio and cruise control
    Heated Seats
    Near Side only door mirror heating (Motors & OS heating all OK)
    Rear Screen heater
    "Oil Sensor Workshop" Warning showing (Oil level OK and driven 150 miles towing since it came on, so no genuine oil pressure or level issue)
    Nothing else that I am aware of.
    I have checked all fuses for these functions and all OK.
  2. Re: Multiple Electrical Failure
    ChillOut Guest
    Further info:-
    This happened a few miles after being parked up following heavy rain - the plenum chamber was blocked and had some water in it - not deep (1-2cm max (when I looked an hour after the rain stopped)).
    There is no sign of water ingress to the car, so I sort of dismissed this as a cause, but where is the "convenience unit" if was looking for it to see if it was damp?
  3. Re: Multiple Electrical Failure
    passenger foot well,under carpet,if you type in the search option above there are some posts about the convenience unit,hth
  4. Re: Multiple Electrical Failure
    Jun 2006
    UK, Mids
    mice chewing wires?
    These problems seem unrelated.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Multiple Electrical Failure
    Norfolk
    Quote Originally Posted by ChillOut View Post
    Horn
    Heated Seats
    Rear Screen heater
    Have you checked relay plate relays and fuses. Climatronic, radio etc may be a bus fault which will be picked up on a scan. Check water hasn't got in on driver side. Helps if you say what model/engine etc
  6. Re: Multiple Electrical Failure
    ChillOut Guest
    Martin, et al: B5 130 TDi Variant Manual 2005.
    I must be getting lazy - I have not checked to see if there is feed to the relevant fuses, but a common supply failure seems most likely to my mind - I wondered if there was a common buss fuse hidden somewhere, but I am told not.
    However, I have entrusted the car to my local VW specialist today - So I will be handing out prizes for the best guess as to what the problem is .
    (Virtual prizes of course )
    Two more facts:-
    1 The steering indicator control stalk MF switch was replaced 10 days ago (by the VW specialist). Perhaps they disturbed some wiring - its not a million miles away from the fuse box)
    2 An odd symptom - the reported MPG has improved 20% since this ocurred. It cannot be a cooindence. Nice if it was genuine, but I doubt it.
  7. Re: Multiple Electrical Failure
    ChillOut Guest
    Hmm, slightly red faced; It was in fact a fuse but fuse 7 or 8 I think, not the fuse any of the actual items that were faulty, but something which supplied some sort of control item for each.
    In short, if you have an electrical failure, forget the fuse key card; check every fuse one by one.
    Cost me, but it did mean I found a blocked plenum chamber in the process, so may have saved myself worse grief down the line.
  8. Re: Multiple Electrical Failure
    Jul 2010
    Brighton
    well at least you've found the fault and it wasn't too expensive
  9. Re: Multiple Electrical Failure
    Apr 2009
    Yes Yes, all well and good.
    BUT!!
    Why did the fuse blow in the
    first place, my dear Watson?
    Regards
    Jim
  10. Re: Multiple Electrical Failure
    Jul 2010
    Brighton
    Quote Originally Posted by yaman View Post
    BUT!!
    Regards
    Jim
    aaah!!! their lies the million doller question WHY??
    if you can find the answer to why, then you have found the answer to the problem (so why did it blow?)
  1. Multiple Electrical trouble
    By A6Dave in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-01-2010, 04:32 PM
  2. 02 Alhambra TDI, Total electrical Failure
    By jonjosar in forum Alhambra
    Last Post: 20-12-2009, 09:40 PM
  3. Please Help Intermittent total electrical failure
    By grumpypanda in forum Alhambra
    Last Post: 29-07-2009, 04:51 PM
  4. Audi A4 Quattro - Multiple Organ Failure
    By AlastairR in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-10-2007, 02:44 PM
  5. multiple electrical failure
    By sparks.01 in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 08:42 PM
