Thread: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
  1. A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    I have a 2000 a31.6se which has a catalogue of electrical faults. The faults are as follows:-
    revcounter, speedo dont work,
    indicators dont work,
    now becoming very difficult to start and when it does the fan stays on for ages after switching the engine off,
    It has had a new crankshaft sensor last year , i have also just had a temperature sensor fitted as the aa guy and my local mechanic thought that was oneof theproblems. I have now been advised to take it to an auto electrician but before i do that i was wondering if anyone has any ideas what the problem is and approximate costs etc.
  2. Re: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    2008 Post(s)
    The rev counter/speedo problem will probably be a faulty instrument pack and the cost of this varies according to what is fitted (used/repaired or new) and who does it.
    The indicator problem is usually a faulty hazard warning light switch and is easy to repair and the part is about £25.
    As for the staring problem, you need a fault code read.
    The fan problem could be a sender or fan controller and would need investigating.
  3. Re: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    Hi, Many thanks for the reply i didnt realise anyone actually had, i fancy having a go at doing the indicator relay. how hard is to get to?
    Jonathan
  4. Re: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    2008 Post(s)
    Very easy, it just pops out, it is the switch itself in the dash.
  5. Re: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    Nov 2006
    As you listed so many symptoms I'd recommend having a fault diagnosis before buying any bits (Find a garage with a VAG diagnostic machine). It only costs about £30 and will isolate the problems rather than depending on a mechanic's guesswork and risking spending money on unnecessary work.
  6. Re: A3 1.6se ELECTRIC FAULTS GALORE HELPIM GOING MAD
    Aug 2010
    nottingham u.k
    Did you find out what was wrong with your car as i have exactly the same problmes now so any help would be great???
    Probs i have
    1. Indicators not working
    2. Rev,milage,time date not working just engine lights on clocks
    3. Car wont start at all
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. World Debut For The All New Audi A3 Cabriolet
    Last Post: 01-12-2007, 06:56 PM
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
