Thread: How to replace front shock absorbers?
Results 1 to 9 of 9
  1. Question How to replace front shock absorbers?
    Aug 2010
    Ware, Herts
    Hi all,
    Please can you help?
    I recently purchased an Audi A4 Avant 1.9 TDI 2004 & appears the front shocks need to be replaced. I like to have a stab at doing these things myself & have purchased 2no new Bilsteins!
    However, it appears the leg assembly is slightly different to the 'norm' and am hoping someone could advise me on how to remove legs? I think i may need to undo a lot more than i was anticipating....am i right?
    Your help/guidance would be much appreciated.
    Rob
  2. Re: How to replace front shock absorbers?
    Mar 2009
    Brighton
    Doh! You went and called them shock absorbers, bit of a no-no round here it seems .
    Check out this thread and you'll see what I mean.
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=103100
    That said, we are a tolerant lot, so I'm sure someone on this forum will be more than pleased to help you with your dampers. Good luck!
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  3. Re: How to replace front shock absorbers?
    Sep 2008
    chester
    17 Post(s)
    what mileage have you got on it? whats wrong with them?should still be ok on a 04 plate,changing the struts will incur more costs,pinch bolt will be seized almost certainly, if it is you'll require heat screwing up both upper control arms.
  4. Re: How to replace front shock absorbers?
    Aug 2010
    Ware, Herts
    Was oil on the floor under near side front wheel. Further investigation led to conclusion damper had leaked out as was wet down the leg.
    As for 'dampers' then appears could be a bit of a pain.
    However a giude would be nice if anyone can point me in the right direction.
    Many thanks in advance
    Rob
  5. Re: How to replace front shock absorbers?
    Aug 2010
    Ware, Herts
    mileage 99,000
  6. Re: How to replace front shock absorbers?
    Oct 2015
    Leicester
    Quote Originally Posted by Nimshoi View Post
    mileage 99,000
    Did you get the dampers replaced in the end? I have a possible issue with excessive road noise which could be the cheap tyres I am replacing tomorrow or wheel bearings or possibly the dampers. I hope it's not the last two issues!
  7. Re: How to replace front shock absorbers?
    Sep 2008
    6 Post(s)
    Quote Originally Posted by S4Cabrio21fan View Post
    You're replying to a 5-year old thread?
    Rule out the wheel bearings as I'd only replace dampers if they were leaking. Yes they get soggy over time, but OE parts aren't cheap. If it's the bearings, then fit OE or equivalent such as FAG.
    Get the car jacked up and get axle stands located. Chock the rear wheels.
    Apply Duck Oil penetrating release on the pinch bolt 2-3 days before attempting the job. The pinch bolt invariably seizes and shifting Excalibur would be easier! Have a new pinch bolt at hand to replace. Undo the nut, but don't remove completely. You can drive it out with a punch and lump hammer. Part of the trouble is getting a decent swing. If it's on ramps it's easier, but can be done on the driveway. With the pinch bolt out, knock the upper control arms up and out of the way with a rubber mallet. If they're worn, consider renewing with Meyle HD arms (4 year warranty). Only tighten the arms under load or you'll goose the rubber bushes.
    Undo the lower strut bolt and remove. Undo the ARB link. With the bonnet open, undo but don't remove the three top strut bolts. Compress the coil spring (ensuring its properly seated). These things can be lethal, so use decent kit such as Draper compressors. On the lower strut, there's a slit where the damper drops into. Spray Duck Oil Penetrating Release on it and wire brush the area so can see movement. Break the corrosion seal and lightly tap with a hammer. Use a suitable metal wedge (cold chisel) to lever open the housing slightly. Undo the top three strut mount bolts. Grabbing the strut assembly you should be able to get some movement now. Use a hammer on the spring seat if it's stuck.
    You can remove the tie-rod end if you wish as it will give you a little more access.
    Remove the assembly, and undo the damper nut. You'll need a 22mm drop ring spanner an Allen bit or Torx bit. Renew the top mount if it looks worn, and check the condition of the bump stops.
    Couple of tips for replacing the damper. Clean the lower strut assembly and use clean engine oil to lube the damper base before inserting back. Also line up the spring so it sits properly in the spring seat. They're are metal tabs it sits within.
    With the damper assembly back in, it's easier to use a jack under the lower balljoint to lift the whole lot back into position. That way you can line up the top mount for the bolts. Also don't over torque the bolts or you'll strip them.
    Last tip, grease the new pinch bolt. Get the tracking checked and alignment.
    More details here with pictures.
    http://www.audizine.com/forum/showthread.php/114492-B6-B7-A4-Suspension-Removal-and-Install
    2016 BMW i3 REx (80k)
  8. Re: How to replace front shock absorbers?
    Oct 2015
    uk
    Don't know about the OP but I certainly appreciated that, I have mine to do when I can get to it and have never worked on A4 suspension before, all links and info copied to my favourites, Thanks very much
  9. Re: How to replace front shock absorbers?
    Oct 2015
    Leicester
    I had no idea it was a 5 year old post, I should have checked the date before posting.
    thanks for the reply.
    cheers
  1. Replacement shock absorbers
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-04-2010, 05:33 PM
  2. Best price/supplier for shock absorbers?
    By Tobster in forum 80 - 90
    Last Post: 08-09-2009, 07:39 PM
  3. Please Help How to replace Passat Rear Shock Absorbers
    By tixy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 06:43 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Shock absorbers Cheap
    By Fozmondo in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 09:52 PM
