Thread: Rear door not opening
Results 1 to 10 of 10
  1. Rear door not opening
    slimgeo Guest
    My rear passenger door will not open from the outside after unlocking the central locking system but after opening from the inside works fine until the car is locked again.
    Has anyone else had this problem or know what could be causing it.
    Any advise would be greatly appreciated.
  2. Re: Rear door not opening
    Norfolk
    It's the cable from the handle to the lock. Search the forum for repair, it's here somewhere.
  3. Re: Rear door not opening
    May 2008
    This one might help. Good instructions and pictures.
    https://www.vwaudiforum.co.uk/forum/s...ht=door+handle
  4. Re: Rear door not opening
    slimgeo Guest
    Thanks guys but does anyone know how to fix cable from the handle to the lock
  5. Re: Rear door not opening
    Norfolk
    Do a search. The remedy is on here. You cable tie the opening cable in place so it doesn't keep jumping out of the slot. There is a thread with pictures.
  6. Re: Rear door not opening
    May 2010
    Crewe
    Seems like my post dissappeared so here goes (You might have tried this already...for the 1st day I had my car I was wondering what was wrong could only open the other doors from the inside)
    When you unlock the car are you pressing the unlock botton once?
    If yes you need to press it twice sequentially
    Post back if this don't work
    P.S. if you have full MFD you should be able to change this it should be something like driver lock if you have half MFD you will need VAG.COM I'm afraid. Someone on here will have one if you don't and I'm susre they'll be more than happy to disable this option for you if you do not want it if not it is off to the dealers/independent garage I'm afraid
    2001 fiat Brava (aka Shelly) Sold/2003 fiat Stilo (aka The Beast) Crashed/2003 fiat Stilo (aka The Beast 2) Sold/2006 Passat S TDI sold
    Current:2007 Honda Civic Type S GT/2009 MKVI GTI
    Call me ESSE
  7. Re: Rear door not opening
    slimgeo Guest
    Thanks for the replies,
    esse_esse...
    I pressed the remote twice as the othe passengers doors all open frome the outside but the strange thing about it al is that after you open the dodgy door fromthe inside once it opens until the next time you lock the car.
    martin1810...
    If it was a cable would the door not operate at all from the outside ?
    thanks again and regards
  8. Re: Rear door not opening
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by esse_esse View Post
    We have two identical threads running on here....
    1996 Laguna 2.2D
    1977 MGB roadster
  9. Re: Rear door not opening
    Norfolk
    Quote Originally Posted by slimgeo View Post
    esse_esse...
    martin1810...
    No the sliping cable produces just what you describe. The outerpart of the cable slips and the door wont open. Opening from the inside then tugs it back in place. Eventually it will slip off and not go back and you will be stuck with a door that doesn't open.
  10. Re: Rear door not opening
    May 2010
    Crewe
    Quote Originally Posted by Quatrelle View Post
    Q you have save the day I was getting worried for a sec.........can the mods merge the two please no point having the same topic running twice
    Call me ESSE
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. Lamborghini gallardo lp 570-4 superleggera
  3. Question Rear speakers including tweeters for Bora?
    By d7029 in forum In Car Entertainment
    Last Post: 05-04-2009, 08:02 PM
  4. expert help required Rear suspension bang!
    By shabazmo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-06-2008, 11:47 AM
