Thread: side repeater
  1. side repeater
    Jun 2010
    glos
    How do I change bulbs in the idicator repeater in the passenger side door mirror please
  2. Re: side repeater
    Dec 2008
    Glasgow
    Hi Mate
    its not a bulb but an LED unit>
    http://cgi.ebay.co.uk/New-Genuine-VW...es_CarParts_SM
    LED's last awful long time, so dont be too fixed on thinking its definatley the LED.
    these things are ridiculously simple to change!! i would advise getting one from a Friendly VW dealer (around £40), try it in to see if it works, if the new unit doesnt work you sir have a problem with the control unit (aka relay unit) in the door or the wiring. (note i said friendly dealer, you can take it back and say you got the wrong part by mistake and you may get your money back)
    Canada
    The indicator is driven by the controller in the door. You will need a. Vcds cable to change that part. I would suggest a fault code scan to help identify the problem
  4. Re: side repeater
    Jun 2010
    glos
    hate to be dull but, it was the led unit as evidenced by a tiny light flashing in the end of the flasher light.I bought a unit from tps(£18.50 + vat) which ,if that'.s ridiculously easy the fit then..... (I've only been a mechanic for 34 years) anyway,the clips you break off taking the mirror back off are on the new led unit,which saves tears.Also,VW have sold "quite a few" so even though leds are tough, they are only as good as the board they are mounted on!
  1. Passat B6 Wing Mirror side repeater removal?
    By Scottiedogg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-11-2014, 10:11 AM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Drivers side heating cold. Passenger side heating fine.
    By Tightpants in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2010, 09:23 PM
  4. Mirror housed side repeater
    By cappuccino in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2008, 08:42 PM
  5. side repeater
    By golfmark5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-06-2007, 12:03 AM
