Thread: UK VW Polo Mark IIIF (6N2) 1.4 Petrol 2000
  1. UK VW Polo Mark IIIF (6N2) 1.4 Petrol 2000
    Aug 2010
    Earth, Solar System
    All the malfunction lights are on when started.
    The car drives fine.
    Rev counter drops to zero every now an then. Red oil light flashing. Air bag light on. ABS light on.
    Hand brake light flashing with oil light and dash chime sounding.
    Ive done a scan of ECU's and found the following.
    VCDS-Lite Version: Release 1.0
    Monday, 16 August 2010, 10:09:32:0
    Chassis Type: 6N - VW Polo
    Scan: 01,02,03,08,15,17,19,25,41,45,46,55,56
    Address 01: Engine Labels: 030-906-032-AUD.LBL
    Controller: 030 906 032 AP
    Component: ME7.5.10 3245
    Coding: 00031
    Shop #: WSC 00000
    5 Faults Found:
    18056 - Powertrain Data Bus: Failure
    P1648 - 35-10 - - - Intermittent
    18058 - Shareware Version. To Decode all DTCs
    P1650 - 35-10 - Please Register/Activate - Intermittent
    18057 - Shareware Version. To Decode all DTCs
    P1649 - 35-10 - Please Register/Activate - Intermittent
    18044 - Powertrain Data Bus: Missing Message from Airbag Controller
    P1636 - 35-10 - - - Intermittent
    16885 - Shareware Version. To Decode all DTCs
    P0501 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 6X0-907-379.LBL
    Controller: 6X0 907 379 B
    Component: ABS 30 IE CAN V004
    Coding: 05603
    Shop #: WSC 00788
    1 Fault Found:
    01312 - Powertrain Data Bus
    37-10 - Faulty - Intermittent
    Any ideas?
  2. Re: UK VW Polo Mark IIIF (6N2) 1.4 Petrol 2000
    Oct 2009
    Staines, UK
    Where's the rest of the scan?
    The modules are not communicating with each other properly
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  3. Re: UK VW Polo Mark IIIF (6N2) 1.4 Petrol 2000
    Norfolk
    This is not a can bus car so the whole thing communicates via the dash panel insert. You either have a bad connection in the dash or you will need a new dash panel insert.
  1. 1.4 TFSI or 1.6 TDI?
    By releaseyourself in forum A1
    Last Post: 10-02-2011, 10:38 PM
  2. replacing front wishbone bushes vw polo tdi 1.4 2003
    By robert1z in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2010, 12:29 AM
  3. vw polo 1.6 gti 2000 air con problem hellllpppppppppppppppp
    By pologti1 in forum Polo - Derby - Lupo - Fox
    Last Post: 22-05-2010, 08:19 PM
  4. VW Polo 1.4 CL 99, Key remote stopped working
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-11-2007, 09:19 AM
  5. iPOD to factory radio - Polo 1.4 2000
    By Lic01 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-07-2007, 09:22 PM
