Thread: AUTO HOLD anyone?
Results 11 to 20 of 21
  1. Re: AUTO HOLD anyone?
    DSG4ME Guest
    No sex or No autohold?
    Make thy choice carefully good sir, and MAN UP will ya
  2. Re: AUTO HOLD anyone?
    Mar 2009
    York
    Hey, at least I won the most important discussion of them all - to get the Passat in the first place... Who knows what else I could have been driving now... Kia anyone?! (no offence meant!)
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: AUTO HOLD anyone?
    Feb 2010
    Louth Ireland....
    Just do it anyway......my OH didn't even notice , then i just pointed it out a short while later and gasped ' you didn't know that was there dear ? ' Duly showed her how to use it and now she thinks its great !
    Ex Passat B6 owner......to many retrofits to mention !
  4. Re: AUTO HOLD anyone?
    Jun 2010
    Notts, UK
    Quote Originally Posted by patomlin76 View Post
    Try telling someone not technically minded that although it's a function that uses the parking brake, I'm not going to brake the parking brake, or put lives at risk by fitting auto hold
    Auto Hold doesn't use the parking brake at all, it just keeps hydraulic pressure on the foot brake system by using the ABS/ESP components.
    It actually gives the parking brake a much easier life as you only use it when you turn the engine off.
    What would she do if you bought a newer PASSAT with it fitted as standard?
    Lee
    2010 VW Passat 2.0CR TDi DSG, Parking Sensors, RCD510 with Media-In Interface and bluetooth, Leather, Cruise, TPM, Auto Hold, 17% Tints, Candy White.
  5. Re: AUTO HOLD anyone?
    Mar 2009
    Sleaford, Lincs, UK
    Quote Originally Posted by logiclee View Post
    Lee
    Wrong... Does use the parking break, if stood for 1 minute or so, open your windows and listen for the motors at the back
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  6. Re: AUTO HOLD anyone?
    DSG4ME Guest
    I thought it was just the front pads doing the holding.
  7. Re: AUTO HOLD anyone?
    #17
    Norfolk
    Logiclee is correct. Pressing the EPB button activates the ABS unit which uses brake fluid pressure to apply all four brakes. If the car remains stationary the EPB will switch on the rear motors whichl wind out the pads. It depends how long you are stopped for. It's the same if you press the EPB button at speed. Pressing the EPB button at speeds above 7 kph activates the ABS unit which pulses brake fluid pressure and applies all four brakes for a controlled stop.
  8. Re: AUTO HOLD anyone?
    #18
    Jun 2010
    Notts, UK
    Quote Originally Posted by ToMBoY_C View Post
    3 minutes according to the handbook I believe.
    Don't need to listen for the motors, the handbrake light comes on. In 5 weeks I've only had the car do this once at roadwork traffic lights. Auto Hold time is long enough to cover normal traffic lights and junctions so certainly cuts down on how often the handbrake motors are used.
    Lee
  9. Re: AUTO HOLD anyone?
    #19
    Mar 2009
    York
    If it comes as standard there wouldn't be an issue.. it's the DIY fit being the problem. On the plus side it saves me a 4-hour job and the money has gone to other improvements on the car (the boot starting to sag down when open being one of them)... Would love to do the fogs but too pricy at the moment...
  10. Re: AUTO HOLD anyone?
    #20
    Oct 2009
    Staines, UK
    Lee
    On mine (retrofiited) the handbrake light doesn't come on when the parking brake is applied after 3 mins.
    It does when you take your seatbelt off, open the door or turn the engine off though
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  1. B6 'Auto Hold' Handbrake warning !
    By claranet in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-05-2010, 08:36 AM
  2. Auto hold - how does it think?
    By lemmylemmy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2010, 09:12 AM
  3. Auto Hold Problem 140TDI SE Estate
    By cruise control in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-04-2008, 08:13 PM
