Thread: front drivers side window cable snapped!
Results 1 to 8 of 8
  1. Smile front drivers side window cable snapped!
    May 2010
    edinburgh
    seems to be a common problem,grinding noise,no window,took skin off to look and right enough cable snapped where it goes into mechanism.
    i have seen a few posts on this, i need to fix myself so any advice on diy approach appreciated.
    is it possible to just to replace the cable itself,or is it the whole mechanism?
    only cars in local scrappies are V,W X reg cars,mine a 2001,any chance they might be interchangable?
    Any help and advice on cheapest option greatly appreciated! cheers.
  2. Re: front drivers side window cable snapped!
    Norfolk
    Cheapest option is a repair cable kit from ebay. Next cheapest is complete replacement of door armour with mechanism. That's alot dearer. Search the forum. It's a common problem.
  3. Re: front drivers side window cable snapped!
    May 2010
    edinburgh
    thanks for that,will check out e bay,appreciated.
  4. Re: front drivers side window cable snapped!
    Jul 2008
    Beverley, East Yorkshire
    Quote Originally Posted by ad777 View Post
    Same problem with my 2001 TDI - drivers side first followed 3 months later by the passenger side. After searhing all the breakers for the complete panel I ended up at the main dealer for a new part - £80 - cheaper than the breakers prices. Unable to help with fitting advice - first repair by a friend, second one at an independent.
    Regards
    Laurie
  5. Re: front drivers side window cable snapped!
    May 2010
    edinburgh
    cheers laurie,going to check breakers yard wed,just got window jammed up just now!
    regards adam
  6. Re: front drivers side window cable snapped!
    Norfolk
    Complete mechanism is about £60 from GSF or eurocar parts.
  7. Re: front drivers side window cable snapped!
    Sep 2009
    Lincoln, England
    6 Post(s)
    Easy job to do, depending on skill level an hour to two hours tops. When the glass is undone from the support, I felt safer taking it out of the car instead of taping it up. The motor just needs drilling off and riveting to the new panel
  8. Re: front drivers side window cable snapped!
    May 2010
    edinburgh
    thank you all for replies,problems all happening now,about to put in another post,so if any advice to be appreciated!thanks again,adam
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. Please Help Golf mk3 cab drivers side window not working.
    By shazad in forum Golf MK3 - 1993 - 1999
    Last Post: 01-01-2010, 12:54 AM
  3. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  4. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
