Thread: Temperature Gauge
Results 1 to 10 of 14
  1. Temperature Gauge
    bristol
    10 Post(s)
    Hi there,since owning my 2.5tdi quattro the temp gauge only ever reads about 70.Replaced green temp sender aswell as thermostat with major service 160k.Still only reads 70??Are there any other sensors?Or is this a dash error?Thanks for your help.Gary
  2. Re: Temperature Gauge
    131 Post(s)
    1978 Post(s)
    I would use VAG-COM/VCDS to check the dash panels reading of temperature digitally and if it said 90 when fully hot and the gauge still said 70, I would do an output test of the gauges where the temp gauge should read FSD and the drop back to 90. If it didn’t, the panel would be faulty.
  3. Re: Temperature Gauge
    Jul 2010
    Aberdeen
    my temp guage does this also n iv been told by audi its my dash insert thats gone.they want 654 including vat n labour to fix it.i bought a second hand dash insert
  4. Re: Temperature Gauge
    bristol
    10 Post(s)
    Did you just replace the temp section of cluster,or the whole thing?
  5. Re: Temperature Gauge
    131 Post(s)
    1978 Post(s)
    You can’t replace the temp gauge, you replace the complete unit. Rebuilding those clusters is a specialist job.
  6. Re: Temperature Gauge
    Jul 2010
    Aberdeen
    yeah unfortuanatly you have to replace the whole thing.it is possible to get them repaired,aparently,but you obviously have to send the cluster away and i dont no how long or how much this would cost
  7. Re: Temperature Gauge
    Ireland
    Whats FSD?
  8. Re: Temperature Gauge
    Ardfern
    8 Post(s)
    FSD= Full Scale Deflection! i.e. needle up to the topstop.
  9. Re: Temperature Gauge
    Jun 2008
    Beverley, east Yorkshire
    the temp guage and fuel guage are easy to replace its only the rev counter and speedo that are integral to the cluster, ive done mine and it took an hour to do with no previous experience, You can buy the guage on its own if you have the part number. Only thing is to make sure you get a b6 one as the needle is different on a b7. Remove cluster then undo the back (3 clips and 4 screws) then the cluster will come out of the case, pop out the wiring connector for the temp guage and the clips that hold the guage in place and fit the new one, reassemble and your done. Dont go buying a whole cluster and waste your cash!
    A4 AVANT 2.5TDI SPORT QUATTRO
  10. Re: Temperature Gauge
    131 Post(s)
    1978 Post(s)
    Where do you buy the parts?
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
  3. Temperature Gauge
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 05:54 PM
  4. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  5. 1998 Audi A4 Temperature Gauge
    By EmmettC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 11:19 AM
