Thread: Electronic noice as I open the door ('99 Bora) .... ?
  1. Question Electronic noice as I open the door ('99 Bora) .... ?
    Oct 2005
    Hi all
    When I unlock the door of my Bora and open the door I get an electronic kind of noise happen ... not long noticed this before .... is it supposed to do this or is something amiss ...
    Thanks for any help!
    Coventry
    Could there be a break in a wire in the loom that feeds in to the door? When the door is closed all electric equipment works ok but when you open the door the contact breaks and then reconnects its self?
    Maybe a lazy central locking solenoid moving slowly?
    Just a thought. Maybe way off the mark.
    Oct 2005
    No idea, All the electrics work just fine. I thought it was some sort of engine reset thing maybe. I ride a Buell STT and when you turn that on it does all sorts of management checks etc before it starts .. but probably not!
    Only does it if I unlock it ... if I shut the door, drive it then get out, and get back in etc it doesnt do it, only if I unlock it .. that might be the central locking solenoid
    Oct 2005
    DId a few tests on this today, I unlocked it and it doesnt do it with any open door except the drivers door ... where would the solenoid be for this so I can see if its faulty (not that I even know what I will be looking at!)
    Oct 2005
    It's your fuel pump priming and it's perfectly normal.
    Oct 2005
    Ah great stuff, thanks for that
  1. A3 door open warning
    By CyprusAndy in forum Audi A3 - Archive Topics
    Last Post: 09-02-2007, 10:54 PM
  2. Passat-Cannot open N/S rear door
    By Fibreron in forum Passat - Archive Topics
    Last Post: 03-01-2007, 12:55 PM
  3. Passat unable to open door
    By Fibreron in forum Archive posts
    Last Post: 18-11-2006, 06:20 PM
  4. Back Door will not open - HELP Please
    By Besenzig in forum Passat - Archive Topics
    Last Post: 08-11-2006, 05:00 PM
  5. Door open or closed?
    By kirley in forum Passat - Archive Topics
    Last Post: 22-04-2006, 04:15 PM
