Thread: Retrofitting auxiliary audio input to RCD 300
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Retrofitting auxiliary audio input to RCD 300
    Jun 2010
    Whaley Bridge Derbyshire
    It's a long time since I did any messing about with a car stereo, but intuition tells me that this should be fairly simple, as long as the thing has an aux input of some sort round the back... Just a case of running a lead round from that to the glovebox.
    Any chance it is that simple?
    If not what's the best option for getting my mp3 player rigged up to the stereo?
  2. Re: Retrofitting auxiliary audio input to RCD 300
    Oct 2009
    Staines, UK
    No, not that easy.
    You need an adapter. Do a search for Connects2 stuff.
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  3. Re: Retrofitting auxiliary audio input to RCD 300
    May 2010
    Crewe
    Quote Originally Posted by A1Dan75 View Post
    The answer to youur question is yes....See my thread (page 4 post #35)
    It emulates your cd changer and allows you to connect any device using a 3.5mm jack....There is another kit similar to that that will do full ipod control but if you're like me and happy with your selections then this will do you just fine with the bonus of being compatible with everything that has a 3.5mm jack
    2001 fiat Brava (aka Shelly) Sold/2003 fiat Stilo (aka The Beast) Crashed/2003 fiat Stilo (aka The Beast 2) Sold/2006 Passat S TDI sold
    Current:2007 Honda Civic Type S GT/2009 MKVI GTI
    Call me ESSE
  4. Re: Retrofitting auxiliary audio input to RCD 300
    Jun 2010
    Cheers guys, that looks just the ticket.
    Car stereos have changed since the big dirty aftermarket unit I installed in my Metro when I was 17!
    Why can't they just have a 3.5mm jack input as standard?!
  5. Re: Retrofitting auxiliary audio input to RCD 300
    May 2010
    Crewe
    That's VW for you cheap a **** get a fiesta or vauxhoe and you'll be laughing 3.5mm is standard
    Get the connects 2 kit (linked in my thread only £30-£35 easy to fit job done in about 5-10 mins
    Tools needed
    1x wire hanger (worked a treat for me and made guding the 3.mm cable through
    1 x torx 10mm screw driver
    sorted
    Call me ESSE
  6. Re: Retrofitting auxiliary audio input to RCD 300
    Jun 2010
    Cheers Esse.
    Where's good to buy from? I just fonud on Halfords, but it's £50.
    Can you briefly outline what's invovled in fitting... do you need to get much dash off to get at the stereo?
  7. Re: Retrofitting auxiliary audio input to RCD 300
    May 2010
    Crewe
    Cheers Esse.
    No prob (click on the fanks button lmao)
    Get it from ebay http://cgi.ebay.co.uk/VW-Jetta-Touar...item518ff86aa1 same place I got mine del in about 2-3 working days.
    1. Remove stereo facia. Easy to do feel round the bottom above the heater control panel and pull off gentley.
    2. Unplug airbag connector (make sure ignition is turned off when you do otherwise airbag light will come on)
    3. Remove the 4 torx screws and slide stereo out.
    4. Plug the connects 2 kit into the cd changer port. You can't get this wrong it will only fit in the one slot.
    5. Strip back some off the csaing round the free single black wire to expose the copper wire. Tie this into one of the holes on HU chasis.
    6. Plug the phono ends of the 3.5mm cable into the box.
    7. Using the wire hanger start from where you want the mp3 player to connected (e.g. glovebox or driver stowage area) and feed it through till you can see it behind the HU.
    Now just simply pull the wire hanger through and you're done.
    8. To play from aux in press the cd button twice and you will have the same screen as in my thread.
    9. Tidy up and place the HU back in and screw in....Plug airbag connector back in and push facia back in all done.
    10. Now go for a drive and enjoy your beats
    Sorted might do some pics to go with this.
    Call me ESSE
    4 0 0
  8. Re: Retrofitting auxiliary audio input to RCD 300
    Jun 2010
    Cheers Esse - thanks allocated all round!
    (does that actually do something then?)
  9. Re: Retrofitting auxiliary audio input to RCD 300
    May 2010
    Crewe
    No not really just give ya a nice warm feeling inside .......................................and highlights helpfull posts
    Let me know if you have any trouble doing it but it's fairly easy
    Call me ESSE
  10. Re: Retrofitting auxiliary audio input to RCD 300
    Jul 2010
    Leicester
    I demand a pic of this wire hanger...you should turn it into a proper tool Esse and get it onto market for ICE installers
    Oh you could put it in the HOW TO section and get it stickied or sumthin
  1. Rcd 300/ rcd 300 mp3 ???
    By lezzer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2010, 11:21 AM
  2. Dension Ice Link connection to RCD 300
    By doriclad in forum In Car Entertainment
    Last Post: 23-06-2009, 11:15 PM
  3. GROM iPod kit for RCD 300 in an '04 GT TDi
    By thecourtenayboy in forum Golf MK5 - 2004 - 2009
    Last Post: 23-02-2009, 07:20 PM
  4. RCD 300 auxiliary input
    By avdvyver in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2008, 09:37 AM
  5. Touran Audio Upgrade
    By nikeluk in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2008, 12:47 AM
