Thread: Driver Window Problem
  1. Driver Window Problem
    Jun 2008
    My driver's window was making a grinding/crunching sound for a little while until eventually refusing to move at all, despite still making the noise. Looks like the motor has gone?
    I have been quoted a ridiculous amount from a garage to get it fixed.
    What is the part I need if I wanted to buy it myself (and pay a local mechanic to fit)?
    Thanks in advance.
  2. Re: Driver Window Problem
    Oct 2005
    The motor should be fine, the grinding noise is usually the cable snapping and getting wound up round the regulator.
    You'll need a new window regulator (inner door skin with the guide channels and cables pre-attached)
  3. Re: Driver Window Problem
    Jun 2008
    Thanks for the quick response.
    Can I get this part from GSF and do you know how much it would cost?
    Also, is it something I could fit myself or is it relatively complicated?
    Thanks again.
  4. Re: Driver Window Problem
    Oct 2005
    I got my two Passat and one Ibiza ones from the now defunct VAGParts.
    I got my most recent one, a Touran rear door from C&R Enterprises.
    I've no idea what the Passat ones cost now, but I paid around £90 a few years ago.
    I wouldn't say it was complicated, but it is a pain in the *** to get it all sorted.
    I used this guide and a lot of trial and error
    VW quoted me £200 just to have a look at what the problem was, which is why I decided to do it myself.
  5. Re: Driver Window Problem
    Hampshire
    Quote Originally Posted by Jonny Chee View Post
    Thanks in advance.
    Search eBay for "Passat window regulator repair kits" or something along those lines - they cost about £20 and are pretty straight forward to fit in an hour or so.
    This sort of thing:
    http://cgi.ebay.co.uk/VW-PASSAT-WIND...item33590bfe6f
    EDIT:
    The guide referred to above looks to be pretty much what I did except that 1. I removed the glass rather than tried to tape it in position (it lifts out easily once the clamp is loosened) and 2. I didn't remove the door lock which meant I had to do everything in situ rather than totally removing the panel, but there was enough slack in everything that it didn't make things particularly difficult.
    2 0 0
  6. Re: Driver Window Problem
    Oct 2005
    Seems there's a Passat repair kit out now - brilliant - so pleased I took 25% of my car to pieces to fix mine.
    Should make the job a lot easier.
  1. Golf mk3 electric window problem
    By iaindhill in forum Golf MK3 - 1993 - 1999
    Last Post: 21-03-2010, 05:07 PM
  2. Please Help Puzzling electric window problem on Mk5 Golf
    By bogpole in forum Golf MK5 - 2004 - 2009
    Last Post: 30-01-2010, 09:23 PM
  3. MK4 Central locking & window problem (rear passenger door)
    By Green MKIV in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2010, 09:16 PM
  4. Polo 6N2 electric window fault
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2008, 10:11 AM
  5. Please Help sharan,05,90bhp ,diesel, drivers electric window problem
    By 2mtec in forum Touran - Sharan - Caravelle
    Last Post: 21-05-2008, 12:44 AM
