Thread: rear wheel hub
  1. rear wheel hub
    Aug 2010
    jerusalem
    hi all.
    last week when done brakes, the last wheel bolt couldn't hold on.. so i understand i need a new wheel hub for my audi 80 2.0 with abs.
    i checked al around and it seems there is no replacment part for the rear.
    original costs around 500 usd which is crazy.
    ahs anyone found a replacment or another alternative??
    the original part number is 8A0 501 653 B .
    any help wil be much appriciated.
    thanks,
    avishay.
  2. Re: rear wheel hub
    If you or a friend has access to workshop facilities there may be a chance of using the next size up bolt to attach the wheel at the failed location.
    It will require drilling and tapping at the useless position and maybe opening up the wheel hole to the larger size and having a new bolt, the head of which could be trimmed to fit your wheel spanner if the head is recessed into alloy wheels.
  3. Re: rear wheel hub
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Any decent Engineering company should be able to put in a Helicoil or insert repair. If this is done make they secure the insert with a high strength Loctite. ( e.g. 603 ). If you call your local engine rebuild speciallist they should be able to point you in the right direction. Don't use the next size up bolt method as this will not have the correct seating contour under the head to suit your wheels. Also wheel bolts are not standard pitch threads . They are fine thread bolts to make sure that they do not come loose.Substituting the original bolt with a standard coarse thread bolt is not recommended and also may affect the wheel balance . Thus you may have to have a wheel balanced specifically for the oversize bolt. This wheel couldn't be used on the other hubs.
    Skoda Octavia II SE 1.9PD TDI
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  3. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  4. 4 Motion soft suspension
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 09:25 AM
  5. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
