Thread: Audi A4 B5 Power Steering Rack
  1. Audi A4 B5 Power Steering Rack
    Hi. My power steering rack failed recently so I started replacing it with a reconditioned one. I followed one of the many write-ups on the internet for the A4 / Passat B5 but I've hit a problem.
    So far I have disconnected the steering column, removed both tie rod ends and released two of the three rack mounting bolts (the easy ones which can be accessed from the engine bay.
    I'm struggling to see how I get access to the final third bolt without stripping down most of the drivers side. Any advice on this would be much appreciated.
    I've seen a few write-ups on the internet for this job but none of them really demonstrate a simple solution for the final third bolt which is accessed from under the engine, though the majority say it can be done simply.
    The car is an A4 B5 2000 x Reg Ajm engine.
    Any help would be well appreciated. I really don't want to have to admit defeat.
  2. Re: Audi A4 B5 Power Steering Rack
    Jul 2008
    stoke on trent
    it is simple but i needed 3 extension bars to reach the thing while lying on my back under car
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  3. Re: Audi A4 B5 Power Steering Rack
    thanks - luckily I've got lots of extension bars but I can't see the bolt and I've got big hands. Assume you had the same issue? What did you remove to get you better access?
  4. Re: Audi A4 B5 Power Steering Rack
    Feb 2010
    Newquay, England
    The third bolt can be undone from above by reaching down the right hand side of the engine. You will need a rachet & a short extension bar. I located the position of the bolt with my right hand then fitted the socket & short extension onto it, holding the extension in place with my left hand I then attached the rachet.
    Best of luck
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. World Debut For The All New Audi A3 Cabriolet
  3. FRANKFURT DEBUT FOR NEW AUDI A4 CABRIOLET
    Last Post: 07-09-2005, 08:30 PM
  4. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
