Thread: 1.9tdi alternator belt tensioner
Results 11 to 20 of 29
  1. Re: 1.9tdi alternator belt tensioner
    1837 Post(s)
    It changed in 2004 from a swing arm tensioner and separate damper bolted on from the front to an all in one spring loaded unit bolted in from behind.
  2. Re: 1.9tdi alternator belt tensioner
    Mar 2007
    9 Post(s)
    yes the one i have is the all in one spring loaded type
  3. Re: 1.9tdi alternator belt tensioner
    Mar 2007
    9 Post(s)
    hi all does anybody know how to replace the type . do you spin it off from the front or have you got to get a spanner in behind
  4. Re: 1.9tdi alternator belt tensioner
    1837 Post(s)
    It is held in position by a locating pin and bolted up from behind.
  5. Re: 1.9tdi alternator belt tensioner
    Mar 2007
    9 Post(s)
    thanks for that crasher its much appreciated
  6. Re: 1.9tdi alternator belt tensioner
    Mar 2013
    West Berks
    Hi, just joined up and been reading this - got myself a nice A4 avante, B6 130 and the idiot i bought it from, after I test drove it, then before i picked it up decided to steam clean the engine - the result I think has caused the alternator pulley to stick
    the steering feels notchy upon returning to centre and is noisy..
    can just the alternator pulley be changed without the front off and removing the tensioner - or am I best getting the clutch pullet, tensioner and belt all changed at once??
  7. Re: 1.9tdi alternator belt tensioner
    #17
    1837 Post(s)
    I struggle to do those without removing the alternator.
  8. Re: 1.9tdi alternator belt tensioner
    #18
    Mar 2010
    County Durham. England
    I have changed the belt , tensioner and removed the alternator from my 2003 a4 without removing the front , lost a bit of skin though.
  9. Re: 1.9tdi alternator belt tensioner
    #19
    1837 Post(s)
    But did you change the alternator pulley?
  10. Re: 1.9tdi alternator belt tensioner
    #20
    Mar 2010
    I removed the alternator, bought the clutch pulley but took it to a garage they changed the pulley ,it cost me a £10 .
  1. Fan Belt Tensioner A6 1.9TDI SE
    By radix in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-10-2009, 01:10 PM
  2. 1.9tdi aux belt & tensioner
    By martyn271985 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2009, 08:58 PM
  3. Late 02 1.9tdi cambelt change
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2009, 06:34 PM
  4. 1Z alternator/aircon belt tensioner
    By john493 in forum Archive posts
    Last Post: 03-02-2008, 10:51 PM
  5. Noisy serpentine belt tensioner - PD 150
    By nath_mkiv_150pd in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2008, 10:41 PM
