Thread: worlds most annoying rattle!!!!!!!!!
Results 1 to 10 of 10
  1. Unhappy worlds most annoying rattle!!!!!!!!!
    Mar 2010
    ipswich
    I have an A4 B6 1.8T sport 2001. About 2 months ago while driving with the window down I heard a rattle coming from outside the car. This noise gets louder and more frequent when driving over bumps and crappy road surfaces, but stops with even the smallest amount of braking.
    I had new discs and pads fitted to the front about 4 months ago so thought that might have something to do with it, so removed all wheels to check calipers, discs etc. and nothing!
    The car passed an MOT last week so surely cant be anything too serious.
    I have jacked the car up numerous times to look underneath but as yet have found nothing.
    You cant hear the rattle with the windows up but its summer!
    Any help or suggestions would be greatly appreciated, cheers
  2. Re: worlds most annoying rattle!!!!!!!!!
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Sir , did you fit genuine pads and discs or decent makes from a motor factors?
    Chances are that you fitted after market products, and why not, and like so many pattern parts the fit is not 100% and therefore your pads are rattling.
    If we ignore you brakes for a moment you might like to inspect your suspension components ,ie; bushes, joints etc
    Good luck
    Stuart
  3. Re: worlds most annoying rattle!!!!!!!!!
    Mar 2010
    ipswich
    Yeah, patten parts I'm afraid. Not ideal I know but moneys pretty tight right about now. Just got the car back on the road after having to sort out broken wire in passenger door ( which meant the door wouldn't open from inside or out, great! ). Spent a fortune on it this year so at the minute I'm not really backing ' the Audi build quality '!
    Right, I'll put my violin away now, lol! I've checked suspension components and can't see anything. The pads feel like they're in there nice and snug but I'll drop it my mechanic tommoro to check I suppose.
  4. Re: worlds most annoying rattle!!!!!!!!!
    Cork
    If the ratteling doesn't stop when you apply the breaks gently then it's not the breaks.. Is it your door handle ?
    copper grease on my pads cured my ratteling. I have heard if left too long they can wear into the calipers, then the only way to fix is replace the calipers too.
    Last edited by defsix; 05-08-2010 at 09:13 AM. Reason: Actually read what i had written.
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  5. Re: worlds most annoying rattle!!!!!!!!!
    Feb 2010
    Bristol, UK
    One of the guys on the Seatcupra.net forum reported a simlar problem with his LC, after countless trips to he dealer and the brakes being taken apart several times, they did eventually cure it with new discs and pads that were OEM. Have you tried copper grease on your pads?
    Options being considered:-
    312mm Brake upgrade - Definite
    Remap - Definite
    Hybrid Turbo and Custom map - hmmmm
    Decat - hmmm
  6. Re: worlds most annoying rattle!!!!!!!!!
    Oct 2009
    Quote Originally Posted by maffchronic View Post
    I too have the same issue, would like to know what this is as my brakes will be getting replace shortly. Now thinking I should wait till I have enough for Audi part!
  7. Re: worlds most annoying rattle!!!!!!!!!
    Mar 2010
    Inverness
    A spot of silicone sealant on the back of the pads will cure it.
    or as stated above, genuine pads
    ive just finished fixing my door wires, both doors needed fixing, bullet connectors and insulation tape did the trick.
    i bought my a4 b6 about 6 months ago and initially was really disapointed with all the rattles and knocks, but ive since solved them all myself and i have to say, for an 8 year old car its pretty amazing..keep at it, its worth it in the end
  8. Re: worlds most annoying rattle!!!!!!!!!
    Oct 2009
    10 Post(s)
    Quote Originally Posted by defsix View Post
    If the ratteling stops when you apply the breaks gently then it's not the breaks.. Is it your door handle ?
    If it stops when you apply the brakes,that shows my, and many others, opinion that the lesser quality pads are rattling in their carrier until the piston applies pressure to them
  9. Re: worlds most annoying rattle!!!!!!!!!
    Ireland
    thats why opinions are great!!!!
    Think its the brakes too, but the door handle ratteling is an easy thing to check and thought it was a good suggestion...
    got new mintex pads with double sided sticky tape on them as standard.. Not a sound out of them, hold in position, great!!
  10. Re: worlds most annoying rattle!!!!!!!!!
    Dec 2007
    crawley, west sussex
    i ve the same problem with my passat, bought new pads from the dealer & the noise went away for a while but it's back, been told to change the calliper retaining clips as these also wear. doing this has solved the problem for a lot of people on the vw passat forum, orderd the clips today so hopefully be able to try them out this weekend, i'll update when ive fitted them, hope this helps.
  1. Dashboard Rattle
    By KiwiA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-06-2015, 09:28 PM
  2. 2005 A6 Rear Brake Caliper Rattle
    By Steve Murray in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 06:48 PM
  3. Question Anyone experience annoying rattle from drivers door?
    By mickey in forum Tiguan
    Last Post: 15-03-2011, 11:22 PM
  4. Question annoying rattle / cat converter
    By wattajessie in forum Golf MK5 - 2004 - 2009
    Last Post: 08-08-2009, 08:07 AM
  5. Best way to stop annoying rattle
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2009, 10:36 PM
