Thread: Pollen filter location
Results 1 to 10 of 10
  1. Pollen filter location
    May 2007
    Hi there could someone please tell me where the pollen filter is located on a 2004 A3.
    I have a smelly aircon, have tried cleanse + recharge but still the same.Maybe I should have tried a new filter first and saved some money
    Cheers in advance.Great site btw
    Feb 2007
    Hertfordshire/North London
    Is it not under the suttel panel? Think There might be two, one on each side.
    May 2007
    Quote Originally Posted by chip-n-spin View Post
    If you tell me where the suttel panel is? I'll have a look
    May 2007
    knee deep in clunge
    14 Post(s)
    under the passenger glove box there is a foam trim,remove the trimand there is a black plastic cap about 10 inches long,slide the cap out and the filter is there.Pull it down and replace.
    Feb 2007
    Sorry mate, scuttle panel is the plastic trim under the Windscreen wipers.
    May 2007
    Quote Originally Posted by a8 tech View Post
    Did it cure the smelly air con problem?
    Regards Boardboy
    May 2007
    Quote Originally Posted by Boardboy View Post
    Regards Boardboy
    No! It's doing my head in now.Thing is it's not a constant smell and (the missus says!?) is not that bad,like a sweet sickly smell.It occurs when you first start the car with aircon on and if you turn aircon off (econ) last for a couple of minutes.Really annoying me now
  9. Post Musty Smells
    Hi deebee,
    Checking the dust/pollen filter. If it is damp or has an unpleasant smell, replace.
    See below link on changing dust/pollen filters...
    https://www.vwaudiforum.co.uk/forum//...ad.php?t=10614
    Cheers,
    Martin
    Last edited by mdre83; 17-06-2007 at 06:47 PM. Reason: Removed information on air-con cleaners and re-gassing has this had already been tried.
    May 2007
    knee deep in clunge
    14 Post(s)
    Treat the a/c with a antibacterial cleaner.Your local a/c workshop should be able to help or you may be able to do it your self.
  1. pollen filter
    By beetleboy in forum Beetle 2000-
    Last Post: 06-02-2010, 06:30 PM
  2. VW Sharan pollen filter
    By kimsue in forum Touran - Sharan - Caravelle
    Last Post: 19-04-2009, 01:27 PM
  3. Pollen Filter
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2007, 03:21 PM
  4. pollen filter seal
    By southwest in forum Passat - Archive Topics
    Last Post: 04-03-2007, 04:15 PM
  5. Pollen filter position
    By aaaa4aaaa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-12-2006, 09:27 AM
