Thread: Car dies!!
Hybrid View
  1. Angry Car dies!!
    I've got a Golf GT TDi 110 Mk 4, and very recently it's been dyin on me. Not no power but complete engine cut out! The reves drop and i loose all my power steering. The main problem is that the car won't start back up for a couple of mins, the coils don't appear on the screen and the engine just doesn't seem to start but just keeps turning over which either leaves me stranded on the motorway or rolling to a stop. I've changed the "fuel cut-off solenoid" but this does not seemed to have helped at all. Some people have mentioned it might be a relay but if so which one!
    Apr 2007
    Repulik Of Mancunia
    Hmm, Could be anything from Fuel Pump or if the whole car cuts out an electrical problem maybe.
    As the power steering is going as well as the engine, it DOES sound like electrical problem, try checking first all the connection to the battery, and the wire to the alternator, if you have a meter check its around 13v+ ideally 13.8. That will rule out the battery connections depending on the results.
    Another option is to get it to a garage for a fault code reading.
    '99 Golf GT-TDI
    MUFC - One Love
    Good Rep Always Appreciated.
    Thanks Big E i'll try that and let you know how it goes.
    May 2007
    knee deep in clunge
    14 Post(s)
    Attachment 647Voltage supply relay for engine control unit.The printed circuit board n the relay cracks and voltage interuption occurs on the secondary side of the relay.No fault code is stored and can be very intermitant.Cost £15 located on additional relay carrier behind drivers side lower dash trim.You can confirm this fault by checking for loss of voltage at the ecu.The position of the ecu relay is 12
  1. Audi A4 - ESP light flashing Engine dies!
    By su51 in forum Chat - Anything with wheels
    Last Post: 24-10-2006, 06:51 PM
  2. 1998 110 TDI dies with revs when cold
    By Antony in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2006, 02:57 PM
