Thread: Electronic throttle body
  1. Electronic throttle body
    Sep 2009
    london
    Hi all I have 2006 3.0tdi and last week the engine light came on phoned Audi and With good efficiency they check the car and told me that it was the throttle body that failed. I wanted to know if this a common problem as I think that a 4 years old car should not have this problem.
    Also does anybody know the cost of an extended warranty for the A8 ?
  2. Re: Electronic throttle body
    Apr 2010
    assen Holland
    Maybe I am missing something here but does a diesel have a throttle? I thought that was just on petrol car. Is a diesel engine not adjusted via the diesel fuel injection pump?
  3. Red face Re: Electronic throttle body
    Sep 2009
    london
    Thanks for the answer but diesel engines do Have throttle body to reduce shut off shake by controlling the amount of air
  4. Re: Electronic throttle body
    Aug 2010
    Leuven, BELGIUM
    Hi, I also have a 2006 3.0tdi A8 and a couple of months ago had the same problem of failed throttle body, jammed in the fully open position. I opened it up and there were almost no teeth left on two of the small plastic gear wheels inside! Rest of the unit was perfect, this expensive part had failed just because its manufacturer used a cheap plastic internal component. Apparently many newer generation throttle bodies fail this way shortly after the warranty expires, it's quite common and not just related to this car or Audi.
    At least its a part which is easily accessible though and simple to change, also the engine seems to drive fine with the valve fully open so you can perhaps take some time to try and find a second hand part at much lower cost.
  5. Re: Electronic throttle body
    131 Post(s)
    1974 Post(s)
    The manifold flaps are a well known failure on this engine.
  6. Re: Electronic throttle body
    Mar 2009
    The other option is if you know any model makers who enjoy a challenge they could make you a new pair of gears out of brass or something more durable! You'd be surprised at what the supplers for this market have.
    http://buggies.builtforfun.co.uk/FactFiles/gears.html
    This is just one such supplier if you do a quick google search you will find more. If you have a vernier you can take some measurements and possibly find the right ones off the shelf and save a lot of dosh.
  1. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  2. From a very fed up owner.
    By pistons in forum Fabia
    Last Post: 31-05-2011, 05:19 PM
  3. Question Audi A3 S reg. 1.6 Erratic iddle and poor starting, Throttle Body? or ?
    By win2kpro in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-04-2010, 11:11 AM
  4. Throttle Body Conversion HELP NEEDED!!!
    By gtxi in forum South West England
    Last Post: 18-12-2009, 08:06 PM
  5. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
