Thread: Help coding passat canbus South or Norfolk
Results 1 to 10 of 12
  1. Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    Hi there
    I am looking to recode my canbus to stop the battery drain issue that comes with the rcd310
    If anyone can help I would be very grateful. I am in Marham Norfolk during the week and Tunbridge Wells Kent at the weekends. Obviously I can drive around a bit to get to you. Thanks
    The car is a 55 Passat TDI Sport
    Adam
  2. Re: Help coding passat canbus South or Norfolk
    Sep 2008
    Kent
    Quote Originally Posted by thestig84 View Post
    Hi there
    Adam
    Hi adam, I take it from the age of your Passat you have upgraded from the rcd300? If this is so it is not a matter of just recoding the unit on the canbus, it will also need a canbus gateway adaptor (£100 ish from a main dealer) then after this is fitted the coding can be done.
    I live in Kent and will happly re code (for beer tokens) it for you after the gateway has been installed.
    Hope this helps
    Lee
  3. Re: Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    Hi Lee
    Thanks very much for the offer. I should have the new canbus gateway in a week or so Ill give you a shout when I have it.
    Can I fit the canbus then drive to you or do we need to fit it there and then?
    Adam
  4. Re: Help coding passat canbus South or Norfolk
    Sep 2008
    Kent
    You can fit it, I will happy drive over to Tunbridge wells. It will probably have to be the following weekend as the wife has given me orders to clear our garage out this weekend!
  5. Re: Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    Lee
    Next weekend is fine. Sunday would be best, how is that for you? Where abouts are you? You sure you dont mind travelling?
    I was reading a guide about the recoding and it says we will need to read the old one. I wont fit the new one but ill take off the trim and have it ready to come out. What do you want in the way of beer tokens?
  6. Re: Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    Can anybody help? Or know where I can get help?!?
  7. Re: Help coding passat canbus South or Norfolk
    Nov 2008
    folkestone.kent
    i take it your man never turned up ??
  8. Re: Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    Unfortunately not. All went a bit quiet on that front.
  9. Re: Help coding passat canbus South or Norfolk
    Nov 2008
    folkestone.kent
    i will contact you in a few days time if you havent got it coded yet and i will do it for you ,let me know if you have got it done.....
  10. Re: Help coding passat canbus South or Norfolk
    Apr 2010
    T.Wells Kent
    That would be amazing, thanks. Im quite sure I wont have it done by then! Your pretty much my only hope.
    Ill meet you wherever is best and let me know what you want for helping out!
    Adam
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. cant find any modules fabia 1.9tdi
    By stevenpeck81 in forum VCDS - Help Requests
    Last Post: 26-10-2010, 09:42 AM
  3. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  4. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:22 PM
