Thread: Solid flywheel conversion mk5 golf
Results 1 to 10 of 17
  1. Solid flywheel conversion mk5 golf
    May 2010
    Dungannon Northern Ireland
    Hi,i replaced my DMF an clutch last August an nearly a year later the DMF is rattling like a rat chawing tin.i have bought a solid flywheel kit for the car.just wondering if anyone has fitted this conversion to there car yet?
  2. Re: Solid flywheel conversion mk5 golf
    Nov 2008
    folkestone.kent
    easy enough to swap as long as you have the kit,and i dont think you will notice a difference between solid and a dmf.....none of our customers have......
  3. Re: Solid flywheel conversion mk5 golf
    May 2010
    cheers,wel once its fitted there wont be any more bother,the only thing to fail is the clutch or the release bearing,which 9 time out of 10 never happens.
  4. Re: Solid flywheel conversion mk5 golf
    May 2010
    Devon England
    didnt know there was a solid kit for the mk5, how much is a kit for a mk5 1.9 tdi 105 bhp and where can i get one from?
    VCDS HEX+CAN CODE READING AND RECODES
    OWN A MK5 GOLF TDI JOIN THE GROUP https://www.vwaudiforum.co.uk/forum/group.php?groupid=23
    2004 mk5, Viezu 140bhp Re-map, GTI front bumper, side skirts, GTI 18in rep wheels, Jamex coilovers, R32 speedo cluster, MFSW, White Roose Motorsport coolant hose's, GTTDI interior, centre consol armrest and ipod dock, leather handbrake lever
  5. Re: Solid flywheel conversion mk5 golf
    May 2010
    i got mine from euro car parts,they do all german parts.the 1 i got was for engine code BKC. valeo solid flywheel kit with clutch and release bearing for Ł340 all in.
  6. Re: Solid flywheel conversion mk5 golf
    Feb 2004
    Yorkshire
    49 Post(s)
    Working in the motor industry, we do not recommend replacing a dual mass with a solid flywheel... we had a presentation from one of the large clutch manufacturers which showed gearboxes destroyed due to these kits...
    Thinks about it... the dual mass is there to take out the vibration, if you remove it were does this vibration go? through the crankshaft and gearbox shaft!
    Ford did a conversion on the Transit van when they had issues with dual mass flywheels, BUT they had to fit a damper to the crank pully to compensate for it's removal to take the vibration out.
    Once they had rectified the problem, they went back to a dual mass set up..
    Although we do sell one or two of these conversions, and we have had very few issues so far, we always state "fit at your own risk" I am not saying you will have any issues, we just say beware of what can happen
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  1. The scirocco r and golf r now available to order
    Last Post: 31-10-2009, 09:03 PM
  2. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 17-09-2009, 08:43 AM
  3. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 15-09-2009, 08:29 PM
  4. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
