Thread: Intermittent Cruise Control
Results 1 to 9 of 9
  1. Intermittent Cruise Control
    Jun 2008
    I have a 2005 Golf 2.0GT Tdi. My cruise control operates intermittently. Sometimes it will stay engaged as normal for a couple of hours then disengage itself (light on the dashboard goes out) and will not work again until the car is turned off then restarted.
    Other times the light on the dash comes on when the ignition is turned on but goes off as soon as the engine is started, before the cruise control is engaged.
    Any ideas on possible causes?
    Gordon
  2. Re: Intermittent Cruise Control
    May 2008
    Clutch or brake pedal switch?
    Get a VAGCOM fault code scan to point you in the right direction.
  3. Re: Intermittent Cruise Control
    Jun 2008
    Issac
    Can only be brake in that case. It's a DSG equipped car therefore no clutch
    Gordon
  4. Re: Intermittent Cruise Control
    Jun 2010
    Ipswich, England
    Interesting to see your post as I'd just logged in to report the same thing and ask for help.
    My car is also a 2005 2.0 GT TDI DSG and does exactly the same - the green cruise control light on the dash disappears apparently at random and needs the "Microsoft" treatment (stop and restart!) to make it work again. It can go for minutes, hours or days between occurences of the problem.
    I'll be due a service shortly so I guess I'll ask them to read the fault codes then unless anyone has any bright ideas. I can't see anything wrong with the brake light switch, is there an additional one specifically for the cruise control?
    Phil
  5. Re: Intermittent Cruise Control
    York, UK
    My car occasionally exhibits this problem. Fortunately it doesn't happen too often, sometimes going several months between it happening.
    I have heard this is caused by a faulty control stalk and is fixed by simply replacing this. Not sure how much this would cost. Probably around the £100 mark and should be easily replaced by yourself.
    I've only once found a fault logged by VCDS which I read to apparently confirm the faulty control stalk theory. Does not always appear after the cruise control trips out though:
    18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
    P1696 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1470 /min
    Torque: 0.0 Nm
    Speed: 53.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11001000
    Bin. Bits: 00000000
    (no units): 1.0
    Hope this helps,
    Stuart
    http://www.stuartdalby.co.uk/vwgolfmk5
  6. Re: Intermittent Cruise Control
    Mar 2008
    i had same fault, but then started out with left hand indicator working when it suited, common fault by all accounts, unit £63 from VW barnsley, had to remove steering wheel airbag etc bit of a pain really, bought the haynes manual of ebay £12,
    Power is nothing without Control!
  7. Re: Intermittent Cruise Control
    York, UK
    Good to know. Was the £63 unit a replacement control stalk? You couldn't reply with the part number could you? Might help me as I think I might need to do the same repair soon.
    Thanks,
    Stuart
  8. Re: Intermittent Cruise Control
    May 2010
    Devon England
    the part number is 8p0 953 513 mate
  9. Re: Intermittent Cruise Control
    Mar 2008
    part number on mine was 1KD 953 513 G from Haysledens VW barnsley,
    that is for a 05 TDI SE , cruise control/indicator in one.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Please Help A4 electrics gone wild
    By Deek2005 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2010, 06:32 PM
  3. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  5. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
