Thread: Audi 80 1.8s gearbox problem
  1. Audi 80 1.8s gearbox problem
    Apr 2009
    Hi to everyone from new member & audi owner!
    I have just bought an old Audi 80 1.8s 1986 and have a gearbox problem.
    When the car is stationary it very difficult to select any gear but when driving it is perfect, I have to really force into reverse gear to back out of my parking place also into 1st gear but when moving the gear change is ok! Now I have found when stationary that if I select 3rd gear first then I can select 1st or reverse without ant problem so a mystery? Can anyone help?
    Thanks!
  2. Re: Audi 80 1.8s gearbox problem
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Possibly could be a worn linkage or the selectors inside the box.Check the rod from below the gearstick to the box for any excess movement etc.
  3. Re: Audi 80 1.8s gearbox problem
    Dec 2007
    8 Post(s)
    Quote Originally Posted by bm50 View Post
    Thanks!
    Another thing to check is. If it has hydraulic clutch try bleeding
    same. If it has cable try adjusting.
    Reverse and first will select if you select gear before starting engine
    If problem is not cable or hydraulics it may be clutch on way out
  4. Thumbs up Re: Audi 80 1.8s gearbox problem
    Apr 2009
    Thanks so much Alan02 & Micheal for your reply's I will look into what you have suggested and will keep you informed in the forum!
    Cheers!
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. A6 1.8T Multitronic Gearbox Failure
    By Herbiv4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2007, 08:08 PM
  3. Record results for vehicles sales, revenue and profit
    Last Post: 12-05-2007, 08:33 PM
  4. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
