Thread: PD140 Bad Missfire - hardly runs
Hybrid View
  1. PD140 Bad Missfire - hardly runs
    May 2008
    Mate of mine has a B6 Passat PD140 and it broke down yesterday leaving his missus and 3 month old stuck on the motorway. breakdown service just towed it home. Popped in and checked for error codes this morning for him - just one 01314 -036 ECM sporadic communications. Googling shows this is quite easy to generate just with a failed start. No other codes.
    It does start, takes a fair amount of cranking - which doesn't feel smooth, and then feels like it is miss firing. Any thoughts on the problem? One of my thoughts was a failed injector - he called his local garage who said unplug the Air flow meter and try to start it. He will try that later but the symptoms seem a bit extreme to me for that.
    Anything sound familiar to others? or any ideas?
  2. Re: PD140 Bad Missfire - hardly runs
    May 2008
    Fuel Pump apparently, and there was a recall on this car for it that was never done. VW now fixing FOC.
  3. Re: PD140 Bad Missfire - hardly runs
    Jun 2010
    amersfoort the netherlands
    miss firing with a diesel?
    If the engine is shut down there must be an error code.
    Thry the disconnected airflow meter.
    Already checked the oil level?
  4. Re: PD140 Bad Missfire - hardly runs
    May 2008
    All fixed for free by vw. Was the fuel pump
  5. Re: PD140 Bad Missfire - hardly runs
    Jun 2010
    Which pump is replaced the one in the petrol tank or the high pressure pump (tandem pump) on the engine?
  6. Re: PD140 Bad Missfire - hardly runs
    May 2008
    Not sure to be honest, I assume the one in the tank, which ever was the subject of the recall.
  1. Missfire problem with my Audi A4 1.8T with Fault Codes
    By JIGGY C in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2017, 12:24 AM
  2. 55 plate B6 with cold start missfire
    By millspeed88 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2010, 05:55 PM
  3. New (front) Tyres - 19500 miles - no bad
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 18-12-2009, 05:59 PM
  4. Please Help missfire on 2.0 fsi engine
    By kingkev1987 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2009, 02:11 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
