Thread: 1.8T dump valve problems??
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: 1.8T dump valve problems??
    133 Post(s)
    1986 Post(s)
    A Passat then, thought it was a Golf for some reason. the AEB engine just seems to hate non recirculating valves.
  2. Re: 1.8T dump valve problems??
    Feb 2011
    london
    The best DV recommended to use for audi A4 b6 1.8T is:
    FORGE PISTON CLOSED LOOP DIVERTOR VALVE
    Part Number: FORGE-FMDV007
    heres the link - http://www.amdessex.com/product.deta...ferenceID=5802
    thats da 1 i have in my a4
  3. Re: 1.8T dump valve problems??
    Dec 2011
    Warwickshire
    I have a 2001 1.8T A4 and had a dump valve fitted (cause I just wanted the noise lol). I've had no problems with my car at all.
    I can ask my garage which one it is if it helps. It only took them literally ten minutes to fit and works perfectly.
  4. Re: 1.8T dump valve problems??
    Mar 2012
    Wirral UK
    all 1.8t's hate BOV's or blow off valves, I don't know why, something do to with the engine requiring the boost back through the intake but again, not sure why this upssets it. As the others have said stick with a Divertor Valve, the standard vag one is ok if your car has not had it's manifold absolute pressure increased (re-map). I went with forge copy off ebay (£30), a little immoral but i didnt have the money for the forge and desperatley needed a new DV with uprated capability. Its been fine so far, just make sure you open it up and grease the seals every 6 months or so (in a similar manner to the forge units).
    If you have cone type air filter you will hear the pooosshh noise on boost dump, or at least I do.
  5. Re: 1.8T dump valve problems??
    133 Post(s)
    1986 Post(s)
    The APR R1 is fit and forget.
  6. Re: 1.8T dump valve problems??
    Mar 2012
    Wirral UK
    true, nice item but it's also over a ton.
    I enjoy little jobs once in a while (gets me away from the mrs) and would prefer to spend the spare £70 on going out with mates. Takes 10 mins to regrease, grease is free from work for me- factor that into your costs!
    the options are there heh.
    i understand crasher is a legend on here and just to be clear, if i had that money spare (currently prioritising a clutch) I'd go for the apr one too.
  7. Re: 1.8T dump valve problems??
    #17
    Mar 2008
    Cliffe, Rochester
    Theres also another item from Dahlback racing which is a very good product just like the APR is. Although it would set you back £150 including postage!
  1. New panel filter or dump valve?????
    By L 6OGS in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2011, 02:44 AM
  2. 1.8t problems
    By goodi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2010, 06:07 PM
  3. EML comes on every few weeks with 3 errors
    By Dark Horse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2010, 07:37 PM
  4. Dump Valve on 1.9 GTD (AAZ)
    By XPS420 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-07-2009, 09:13 PM
  5. dump valve...??
    By leepassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2009, 10:28 AM
