Thread: Engine decoke & cambelt
  1. Engine decoke & cambelt
    Apr 2009
    Going to change cambelt on my 2.0ltr 8v bora car done 160,000 miles so thought i would do a decoke cos i got a slight miss on 1 cylinder done plugs leads and coil so last thing to do is valves cnt think of what else it could be. Any advice on changing belt and removing head would be appreciated, also is it worth fitting iridium plugs
  2. Re: Engine decoke & cambelt
    2009 Post(s)
    Have you done a code read? What is your cars engine type code?
  3. Re: Engine decoke & cambelt
    Apr 2009
    havent done fault code engine code is apk
  4. Re: Engine decoke & cambelt
    2009 Post(s)
    So rather than do a fault code read you were going to pull the head off….
  5. Re: Engine decoke & cambelt
    Apr 2009
    Just thinking after 160,000 it could do with decoke cos i get a puff of smoke now and then thought it could be valve seals
  6. Re: Engine decoke & cambelt
    2009 Post(s)
    It would probably need guides as well but just the valve oil seals can be done without removing the head if you have access to a compressed air supply and the special tools.
  1. ADY engine won't always start
    By diagman in forum Alhambra
    Last Post: 06-11-2015, 03:04 PM
  2. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  3. Volkswagen Tsi Claims Category Honour In Engine Awards
    Last Post: 12-05-2007, 08:40 PM
  4. Newbie - first post- looking to buy!
    By woza in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2007, 01:41 AM
