Thread: A4 3.0 V6 engine misfiring - codes
  1. A4 3.0 V6 engine misfiring - codes
    Jun 2007
    Liverpool
    11 Post(s)
    Anyone shed any light on these please?
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E0 909 559 M HW: 8E0 909 059
    Component: 3.0L V6/5V 0010
    Coding: 0011514
    Shop #: WSC 00672 785 00200
    VCID: 3F893B561715
    5 Faults Found:
    17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
    P1140 - 008 - Implausible Signal - Intermittent
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 008 - Implausible Signal - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded
    16690 - Cylinder 6: Misfire Detected
    P0306 - 001 - Upper Limit Exceeded
    Readiness: 0000 0000
    Cheers in advance guys
  2. Re: A4 3.0 V6 engine misfiring - codes
    132 Post(s)
    1979 Post(s)
    That could be coil packs 2 and 6 but I have had this on these engines when the cam timing adjuster valves fail.
  3. Re: A4 3.0 V6 engine misfiring - codes
    Jun 2007
    Liverpool
    11 Post(s)
    Cheers Crasher, I'm guessing 2 coil packs going would be beter than cam timing adjuster valves failing?
    Is there an easy way of checking the coil packs? And which ones are cylinders 2 and 6 (probably very stupid question but apologies)
    Also, if it is the cam timing adjusted valves going, what sort of job/cost will this be?
    Thanks again mate
  4. Re: A4 3.0 V6 engine misfiring - codes
    132 Post(s)
    1979 Post(s)
    Yes but the cam timing adjuster valves are easy to change if VAG UK have any stock. They are around £80 each and are bolted in through the cam covers, quite an easy job to do.
  5. Re: A4 3.0 V6 engine misfiring - codes
    Jun 2007
    Liverpool
    11 Post(s)
    Cheers again Crasher, is there an easy way of seeing if its the coil packs, or the cam timing adjusters?
  6. Re: A4 3.0 V6 engine misfiring - codes
    132 Post(s)
    1979 Post(s)
    Not an easy one, it is down to experience and lots of time studying measuring blocks.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Balance of power shifts for 2011 model year audi q7
    Last Post: 02-05-2010, 05:12 PM
  3. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
