Thread: CO failure
  1. CO failure
    Jul 2010
    london
    I have aan Audi A4 1.6L 2003 Model.
    Few days back, why driving my car i found the Engine light on the dash board pop up.
    i immediatly drove the car to the nearest garage to check the fault code.
    The guys at the garage found code P-0420 for the cause of the engine light to pop. they said they found no other error code than that.
    they carried emmision test and found CO fail. they did twice FAST IDLE TEST and found the value to .396 & .398. the printed copy says the limite value to be .300. so i assume it is a little way high.
    The mechanic said i might need to have catalytic convertor and lamda sensor replaced to fix the issue.
    My question is
    1. would this be real cause for the engine light to pop or there could be any other issue?
    2. do i need to change catalytic convertor and lamda sensor to fix the issue or there is any other alternative. the reason i am asking is the mecahnic said the entire replacement would cost me roughly £600 which is expensive.
    3. can you please guide me if there is any cheaper alternative
    The mechanic said he has disabled the sensor for the code, the engine light stopped popping for a day after that. but it has srated reappering once again
    your comments are appreciated
  2. Re: CO failure
    Dec 2007
    details for your code
    [hide]
    16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
    Possible Causes
    • Leakage in Intake and/or Exhaust System
    • Catalyst faulty
    • Oxygen Sensor(s) faulty
    • Oxygen Sensor(s) Control faulty
    Possible Solutions
    • Check Intake and Exhaust System for Leaks
    • Check Catalyst
    • Check Oxygen Sensor(s)
    • Check Oxygen Sensor(s) Control
      • Perform Oxygen Sensor(s) Aging Check
    Special Notes
    i had this in a 1,6 A3 was a 02 sensor
  1. Getting rid
    By GarJE in forum Golf MK5 - 2004 - 2009
    Last Post: 29-12-2010, 09:13 PM
  2. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
  3. Timing Chain failure 2004 A6 3.0TDI Quattro
    By fitgym1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-08-2009, 11:10 PM
  4. Gearbox Failure
    By shepton00 in forum Passat - Archive Topics
    Last Post: 21-09-2007, 03:49 PM
  5. A4 1.8T turbo failure
    By brewster in forum Audi A4 - Archive Topics
    Last Post: 09-02-2007, 07:52 PM
