Thread: How many miles on a set of tyres?
Results 1 to 10 of 11
  1. How many miles on a set of tyres?
    Kent, England
    Hi all, just curious really, as my LT35 came new with Bridgestones on, I have now done 40,000 miles on the original tyres ( rears are low, fronts have at least 10k left) and I have never changed the brake pads yet, is this normal??
    Well, had a few views but no replies, guess nobody cares.
    Anyway, update; replaced one rear tyre for new Bridgestone, and used the spare ( never been out of the cradle) on the other side, and replaced the spare with the best of the worn tyres.
    Tyre fitter said he'd never known anybody to get 40k from a set of tyres on this type of vehicle, constantly loaded to about 3/4 tonne.
    Still running on the original front tyres, I'll let you know how I get on, if anyone is interested, that is!
    Kent, England
    Quote Originally Posted by plumb bob View Post
    Well 53 views and over a month and not one single reply, guess nobody gives a **** or has the courtesy to even post, ain,t much of a forum!
    Auckland N.Z.
    Don't know about LT. On out T4's we get min 100k front and rear with Jap tyres. OEM Continentals suffered tread separation at 40k. Keep pressures up near max listed on tyre. Brake pads on seem to last about 65k depending on driver, front rotors on VWs seem soft and generally last only 2 sets of pads.
    Smile, someone out there must love ya.
    John
    Kent, England
    Quote Originally Posted by Freshup View Post
    John
    Thanks again John,
  5. Re: How many miles on a set of tyres?
    Foxton New Zealand
    I'm new at this but wanted to ask if anyone has a 2003/4 LT35 2.5 TDI and if they have the owners manual. Can you tell me what tyres does VW recommend front and back with pressures
  6. Re: How many miles on a set of tyres?
    Hi Bellinger,
    Tyre size are 225/70/15, front pressure 40psi, rear 65psi, (as per makers plate)
    To find plate you look at the rear part of the drivers side door pillar just below the catch for the door lock there should be a sticker or plate and the info for your vehicle should be on there, (providing sticker or plate has not been moved of course)
    hope this helps
    rayl
  7. Re: How many miles on a set of tyres?
    Foxton New Zealand
    Thank you rayl. That was what I wanted to know. Can anyone now tell me what is the best tyre manufacturer of the 225/70/15 tyre and why - best wet weather, best milage etc
  8. Re: How many miles on a set of tyres?
    Hi Bellinger,
    I prefere Bridgestone, reason being, out of the 400,000+ miles i've done in my van since new bridgestone,s have been used for over 300,000 of these miles and i have never had any trouble from them plus i was getting 60,000 - 70,000 miles out of a set of them front and back , i found they grip in the wet and on braking in wet or dry.
    I have tried other makes , but the milage or grip in my opinion was no where near as good as Bridgestone,s, so i stick with them.
    rayl
  9. Re: How many miles on a set of tyres?
    Foxton New Zealand
    Thanks Rayl,
    The New Zealand website says the Bridgestone R623 225/70/15 was developed for the VW Transporter but does not give the Ply Rating - I assume it is 8
  10. Re: How many miles on a set of tyres?
    Hi Bellinger,
    yes 8 ply rating, the ones i have at mo are Bridgestone Duravis,the ones the van came with from new i could not get i belive these were the 265's
    but the equivlent that were put on were just as good. I was told when tyres are new they emit an oil like substance till tyres are bedded in a bit which makes them a little slippy at first, but i had no probs from them at all
    rayl
  1. How many miles has your Golf done?
    By VWSmudge in forum Chat - Anything with wheels
    Last Post: 01-04-2007, 06:07 PM
  2. Miles per tank
    By Stevebarns in forum Passat - Archive Topics
    Last Post: 17-01-2007, 04:52 PM
  3. A4 1.8T '03 97k miles...should I buy ?
    By richjthorpe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2007, 09:52 AM
  4. 20,000 miles on - the experience gets no better!
    By AndrewT in forum Passat - Archive Topics
    Last Post: 01-01-2007, 06:49 PM
