Thread: loss of power at 70mph
  1. loss of power at 70mph
    Mar 2008
    Preston
    hi, i have recently posted up threads about my car losing coolant and not knowing the issue. however i have had the head gasket done on the car and all is well.
    for those who dont know i have a golf mk4 pd115 ajm engine code.
    since having this done the car does not have any pull and drives ruggid. its usual oick up has gone slugish. Now i am having to use one lower gear for speeds i would do usually in higher gears for example at 60mph in 6th gear car would pick up speed fine and now i have to use gear 5.
    it feels like there is no turbo on the car!! 1st gears 2nd and 3rd can be ok at times but when the car is on motorway doing 70-80mph you put your foot down and nothing happens, the revs stay stuck around 2000rpm.
    Can anyone help??
    p.s i unpluged the air mass meter and it went worse there was not pull in any gears
  2. Re: loss of power at 70mph
    Southampton, UK.
    Probably the reason nobody has responded is that this kind of problem has been covered over and over again and various suggestions can be found by doing a search. Scan for fault codes is your best best before guessing. Could be a boost leak or a faulty MAF (which often doesn't log a fault)
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  1. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  2. 1997 1.9TDI power loss & noise?
    By Possu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2010, 08:40 PM
  3. Poor MPG and loss in Power
    By amz in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2009, 11:42 AM
  4. Power loss problem SOLVED !!! A must read
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2008, 02:26 PM
  5. power loss
    By john grout in forum Passat - Archive Topics
    Last Post: 21-01-2008, 01:14 PM
