Thread: brake fluid
  1. brake fluid
    Mar 2007
    south wales
    i want to change my brake fluid,it specifies in the service schedule to use genuine vw fluid only,has anyone any further advice on this?
    surely if the old fluid is removed first and good quality stuff put back in there wont be an issue?
    2002 1.8t sport estate
    7 Post(s)
    dot 4 or 5.1 should be ok.
    Don't use dot 5 though it is different and will cause brake failure.
    Also, do your homework on this before you start as the bleeding process can be problematical in that you wont easily get a hard pedal back unless you do it exactly right.
  1. Brake fluid - dot 4 or 5.1?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2007, 10:10 AM
  2. A6 1.8T Brake fluid warning light
    By Cambrai in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-03-2007, 12:39 PM
  3. Brake Fluid, when was yours changed?
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2007, 01:33 AM
  4. Passat Brake Fluid Change...
    By TDi_B5 in forum Passat - Archive Topics
    Last Post: 01-02-2007, 01:08 AM
  5. Do I need to change brake fluid?
    By curiousgeorge in forum Archive posts
    Last Post: 16-01-2007, 09:08 PM
