Thread: 1.6 A3 cutting out and loss of power?
  1. 1.6 A3 cutting out and loss of power?
    Jun 2010
    Plymouth
    A friend of mine owns an 1998 (S) A3 1.6 Sport that has unfortunately developed a fault. She thinks this is a electrical fault as sometimes the car will just cut out but only on tickover and only if its been standing for around 5 mins. Also theres a lack of power when driving.
    Any ideas please for a damsel in distress?
    I am ok with a set of spanners but have no access to diagnostics to look into the fault?
    Neil
  2. Re: 1.6 A3 cutting out and loss of power?
    Sep 2009
    South Wales
    With the lack of diagnostics, I would start by checking plugs/leads/dizzy & ignition coil.
    Engine code would be handy, also if you can get a codescan will help you trace the fault quicker
  3. Re: 1.6 A3 cutting out and loss of power?
    Apr 2014
    Disconnect the maf and see if it will rev if so there is your faulty part but a code may need to be reset car won't tick over though while no maf
    Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
    Using Tapatalk
