Thread: 5 speed auto problem
  1. 5 speed auto problem
    Slough
    The car goes fine in speed from 60 on wards but when i put the foot down it over revs and DOES NOT GO FASTER?
    Is this the torqe converter or is it the gearbox?
    please help as i need to fix asap... the car has had a newer engine fitted by me recently. Everything else is good except on hard aceleration its slow....
    Thanks in advance
    sorry about spelling mistakes
  2. Re: 5 speed auto problem
    Oct 2009
    Doncaster
    what engine was in previously and whats in now?
  3. Re: 5 speed auto problem
    Slough
    The original engine was an ACK and changed to APR the only diffrence in both was the throttle bodies... before the engine change the car under hard acceleration would jolt in 3rd to 4th which it still does but now it does not kickdown with power just over revs then after going to 5000rpm will go down a gear... could be the converter would like to know if i am thinking on the right lines.....
    thanks
  4. Re: 5 speed auto problem
    Oct 2009
    Doncaster
    your best bet is to ask "Crasher" or "Peter D" they have a very good knowledge on audi's
  5. Re: 5 speed auto problem
    May 2007
    sounds like the autobox is flaring. Caused either a blown piston seal, or issue with the valve block.
    Basically the brake bands cannot hold the sections of the box steady, so the box flares
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. VW Sharan VR6 (99) Auto gearbox problem
    By bluemozzer in forum Touran - Sharan - Caravelle
    Last Post: 01-01-2013, 11:53 AM
  3. In-Car Speed Limiters Go On Trial In London
    Last Post: 12-06-2009, 05:46 PM
  4. sharan vr6 auto gearbox problem
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 30-06-2008, 10:04 PM
  5. Erratic Idle Speed 1.8T AUTO
    By RunRabbitRun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2008, 10:49 PM
