Thread: Serious help needed please!!!!
  1. Serious help needed please!!!!
    Jul 2010
    Dundee, Scotland
    Hi all, Just joined this forum page today and need some help from someone who know's about 2.8 v6 coupe 92 plate. When i bought my car car i got it cheap as it failed on it's mot and i have decided to do it up and put it through it's mot again. The main points were it has a water & coolant leak the fuel lines need replaced and the front and rear brake discs need replacing. If anybody knows what i should do about the water & coolant leak can they let me know. I'm in the process of buying kunifer coil packs and fixings and getting someone to replace them but i need to source good cheap brake discs. Any help will be appreciated. Thanks.
  2. Re: Serious help needed please!!!!
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Sugest you concentrate on the more important problem first - the coolant leak . Every else is quite straight forward .
    Skoda Octavia II SE 1.9PD TDI
  3. Re: Serious help needed please!!!!
    Jul 2010
    Dundee, Scotland
    Hi Thanks for the info but how do i sort the coolant leak. Thanks.
  4. Re: Serious help needed please!!!!
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    To find any coolant leak sources, you need to check all the components of the coolant system for any discolouration left by any leaks or signs of weeping. This is probably best carried out on ramps. The radiator, oil cooler, water pump, thermostat, hoses ,etc all need to be closely examined. There is a dye that can be added to the expansion tank to help make any leaks more visible. If you search for “coolant leak dye” on the internet you should find more details of the dye. I would imagine most motor factors will sell it. The radiator expansion tank should be checked for any sign of scum or oily film on the sides of the tank. Any evidence here could mean you have a leaking head gasket.
    Good luck.
  1. AUDI A3 2.0 FSI Desparate help needed
    By birdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-08-2010, 09:16 PM
  2. Serious problem and i need advise
    By Vapor in forum Golf MK5 - 2004 - 2009
    Last Post: 05-12-2009, 06:55 PM
  3. 1.4 16v problems (need to know if these are serious)
    By vw09 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-04-2009, 03:27 AM
  4. -- Serious Help Needed --
    By P0WERS160 in forum Chat - Anything with wheels
    Last Post: 09-03-2008, 10:21 PM
  5. Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
    By airforcedave in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2008, 04:33 PM
