Thread: Bora indicator problem
Results 1 to 10 of 11
  1. Bora indicator problem
    Jun 2007
    I wonder whether anyone could help me! I have a 2000 Bora and my r/h indicator seems to have packed up!...when I indicate left it's ok but when I indicate right the indicator noise goes ten to the dozen but no indicator lights (the bulbs are fine!) I am just wondering whether this is an easy fix as my haynes manual does'nt mention anything about this problem. Thank you
    May 2007
    17 Post(s)
    What happens when you switch the hazard lights on?
    Jim.
    Jun 2007
    Hello Jim
    all four indicator lights come on as well as the side repeater lights!
    Dave
    May 2007
    17 Post(s)
    Sorry for not replying sooner. I've been unable of access the net for a few days.
    It sounds to me like your problem could be the hazard switch. I think (and I'll check to be sure) the indicators are wired through the hazard switch. I think contacts in the hazard switch that link the R/H indicator switch to the bulbs has gone open circuit. That is why the flasher unit is giving you the rapid ticking.
    Jim.
    Coventry
    It may also be the relay. Left, right and hazards all use it.
    Jun 2007
    Ok, thank you for the replies....I will have a look and see if its a bad contact at the hazzard light swich first. Funny thing though, the r/h indicator has actually worked on my 10 minute drive home from work twice since my original post (but the vast majority of the time it does'nt!)
    May 2007
    17 Post(s)
    Quote Originally Posted by GOLFMK5GTTDI View Post
    No, it's unlikely to be the flasher unit (relay) as it's only the right hand side that is showing a problem. Both the left hand indicators and hazard lights are working normally, and as you said the flasher unit is common to all three.
    Jim.
  1. Indicator Problem
    By Hembrowr in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2010, 07:40 PM
  2. indicator problem
    By graham.hassall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2007, 03:42 PM
  3. Indicator problem
    By name43 in forum Passat - Archive Topics
    Last Post: 22-02-2007, 04:52 PM
  4. Indicator problem
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-02-2007, 03:53 PM
  5. Bora TDi Service Indicator
    By Ewan151 in forum Bora - 1998 - 2005
    Last Post: 07-09-2006, 01:05 PM
