Thread: vw door alignment
  1. vw door alignment
    annegibbons Guest
    Our vw mk iv golf door is not fitting flush into the door frame.Does anyone know how to adjust the door
  2. Re: vw door alignment
    Oct 2010
    Middx, UK
    if its anything like the corrado, there are two adjustment points - one the door lock pin which iirc is a 15mm head. Just loosen this and slide inwards a few mm and tighten up. The other, which tbh wont really give you much movement is the door hinges themselves, which are also 15mm, but need a socket. Loosen slightly, reposition teh door and tighten well. Ideally you need two people for this. HTH
    A4 B6 S-line, 90k miles
  3. Re: vw door alignment
    134 Post(s)
    2009 Post(s)
    The official quote on this is;
    Adjusting door
    To ensure a correct door adjustment the door hinge must be loosened on the pillar. Other measures, such as raising the door, have no effect. Subsequent pressure from above will cause the door to sack again.
    The door alignment tool -3320- with bit -3320/2- is to be used for this
    If it is necessary to loosen the upper door hinge on the A-pillar from the inside, socket driver -3410- can be used. To do this, remove dash panel.
  1. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  2. Carmakers Porsche and VW to merge
    By zf44 in forum Chat - Anything with wheels
    Last Post: 08-05-2009, 09:23 PM
  3. how can I tell if I've got a PD engine
    By dilly in forum Passat - Archive Topics
    Last Post: 04-10-2007, 06:51 PM
  4. Passat TDI locking brakes
    By Cathyscar in forum Archive posts
    Last Post: 23-04-2007, 11:41 PM
