Thread: help s3 2001 speedo not working after dis-connecting battery
  1. help s3 2001 speedo not working after dis-connecting battery
    Aug 2010
    nottingham u.k
    hi all im new here and need help urgent
    iv got an audi s3 2001 and after some nob decided he was abit jelous of it he decided to break my windows and set fire to to. but this nob wasnt very clever as he decided to burn it outside a fire station litterly. anyway fire brigade put the fire out straight away and damage was smoke damage really. and iv been re building it for months now
    before i stripped interior out the clocks and car started fine but now im nearly finished i got a new battery and fired it up other day for first time in three months and noticed that battery, epc, airbag lights come on the dash but non of the milage or time would work on the clocks and wouldnt start for abit. after locking/opening the doors a few times and putting key in ignition and trying to start it and pressing unlock whilst in the ignition the clocks milage/ time and brake pad lights eventually came on and the car started fine had it running for 10 mins or so
    after turning it off i cannot get the milage and time back now its all just blank with only the battery,epc,airbag lights coming on now and hence wont start as immoboliser kicks in.
    anyone got any ideas on how to fix it ???/
  2. Re: help s3 2001 speedo not working after dis-connecting battery
    Mar 2008
    High Wycombe
    Have you had a fault code read?
    You can get yourself a cheap cable (about £15), and the shareware version of vag-com / vcds (free, $99 if you then register it for the advanced features).
    That will tell you if there are any problems with the electronic modules. It should give you a list of fault codes which otehr people here will be able to help with.
    It might be that the keys need recoding to the immobiliser.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. 1.8t quattro sport speedo not working.
    By sharpy1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-04-2012, 06:35 AM
  2. Please Help battery light not working and battery not charging
    By nomanjuice in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2010, 07:25 AM
  3. 2002 A4 Avant battery problem
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2010, 01:55 AM
  4. electronic speedo is not working
    By Dataman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 08:21 PM
  5. Dynamism and driving pleasure - The new Audi S3
    Last Post: 05-08-2006, 08:36 PM
