Thread: A4 2.5tdi 2006, Lots of black smoke, loss of power
  1. A4 2.5tdi 2006, Lots of black smoke, loss of power
    Sep 2015
    Manchester
    It started couple of months ago. It was a bit of black smoke at beginning and it got to that stage that even after light acceleration extensive amount of black smoke comes out. With that also problems with power loss. Its fine when pulling off slowly, only very shaking could be felt. But if I try to pull off quicker, I get only loads of smoke and no power.
    Today on the way to mechanic, car started shaking at idle, sounded like one of the cylinders misfiring and even more loss of power, like in limp mode. Mechanic told me that problem probably with one or more cylinders, probably compression and that it will cost a lot to investigate further, he suggested to me that I should rather try to get rid of the car, sell as it is.
    I took car back from mechanic, on the way home, all came back to "normal", no misfiring and more power.
    Now I am thinking that mechanic concentrated more on fact that engine misfiring and not on smoking. Could "black smoke problem" cause misfire of one of the cylinder for that moment?
    Codes he found was about glow plugs.
    I have visually inspected all pipes for air leaks, could not see anything wrong there.
    What do you thing problem could be? or you agree with mechanic on this?
  2. Re: A4 2.5tdi 2006, Lots of black smoke, loss of power
    135 Post(s)
    2042 Post(s)
    That could be badly worn cams/lifters. Done professionally this is more than the car is worth but if it is a good car, it may be worth it to you.
  3. Re: A4 2.5tdi 2006, Lots of black smoke, loss of power
    Jan 2010
    southport
    Black smoke could be,badly blocked air filter,Injector fault or fuel pump fault.
    Black smoke is normally over fueling or wrong Air to fuel mix.
    Black smoke fuel related,Blue smoke Oil related and White smoke is Water related burning of.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  1. Help with a3, power loss, black smoke etc
    By deek19790 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-11-2014, 10:40 PM
  2. Please Help Lots of black smoke, loss of power and now rough idle when cold
    By badboi331 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-10-2011, 08:40 PM
  3. Loss of Power/ Black Smoke
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-04-2010, 04:53 PM
  4. Black smoke and loss of power
    By shabazmo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-05-2009, 05:04 PM
