Thread: 2002 TDi Polo with intermittent heavy steering, steering wheel warning lamp, brake pad warning lamp, and fuel gauge faults!
  1. Re: 2002 TDi Polo with intermittent heavy steering, steering wheel warning lamp, brake pad warning lamp, and fuel gauge faults!
    Jul 2010
    Brum
    Hi mate, regarding the heavy steering the only thing I can think of power steering pump, or something to do with the fluid, maybe an airlock?
  2. Re: 2002 TDi Polo with intermittent heavy steering, steering wheel warning lamp, brake pad warning lamp, and fuel gauge faults!
    May 2008
    Quote Originally Posted by Brummypolo View Post
    Thanks Brummypolo, have you ever topped up the fluid on one of these Polos? The resevoir is on the pump under the battery, the level looks ok-it's on the bottom mark (when cold), I've done a search of the forums I see others have had problems with speed sensors, does anyone know where the sensor is fitted? I presume it doesn't pick up off an ABS sensor?
  3. Re: 2002 TDi Polo with intermittent heavy steering, steering wheel warning lamp, brake pad warning lamp, and fuel gauge faults!
    Jul 2010
    Brum
    Quote Originally Posted by 2002A31.8 View Post
    To be honest my knowledge of cars doesnt strectch very far, havent had my polo very long either. Ive had a search around on the net but cant seem to find where the speed sensor is located, may be a good idea to pop into a vw garage and ask them
  4. Re: 2002 TDi Polo with intermittent heavy steering, steering wheel warning lamp, brake pad warning lamp, and fuel gauge faults!
    May 2008
    Hi everyone, I think we've fixed the fuel guage and brake pad warning lamp faults, the black multiplug socket going to the speedo head had dry joints inside. This had been repaired before so maybe it's a common fault?
    However the electro/hydraulic power-steering still feels heavy sometimes when manoeuvring at slow speeds, also the warning lamp came on again today, when I pulled up and felt the steering it felt heavy (definitely assisted but too heavy) so I switched off the ignition-restarted the car and the steering felt light.
    We've checked the fluid level. all the connectors on the pump, battery, underbonnet fuses and earth points. someone else suggested a speed sensor in a previous thread, whereabouts is this located? Is it the one fitted to the steering rack where the column meets it? Does it measure the cars speed or the speed the steering wheel is being turned?
    Thanks alot!!
    Paul and Zoe
  1. How To DIS AND CRUISE RETRO FIT b6+b7
    By a8 tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2014, 09:43 AM
  2. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  3. Bentley announces detailed specification of new mulsanne
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
