Thread: Lt 28 problems ???
Results 1 to 9 of 9
  1. Unhappy Lt 28 problems ???
    Jun 2010
    eastwood
    hi there, just wondered wether any of you guys had the same issues or had heard about then with your vw lt28 or similar model van.
    also i think same as the mercedes sprinter ?
    anyway ours is on a 51 plate ( but is a 02 model )
    issues we have :
    heater blower and demister doesnt work , although it will on occaission ( checked fuse )
    drivers side headlamp main beam doesnt work ? ( changed bulb and checked fuse )
    parking light dont work ( not bothered about it though )
    anyone shed anylight how to fix and stuff
    all the best
    richard
    nottinghamshire
    please email me at riche100@hotmail.com thanks
  2. Re: Lt 28 problems ???
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Heater Blower is usually the connection on the plug to the motor. Remove covering over motor housing with fan `ON`, and move plug about to check. Usually its the motor faulty if it starts to run. Also, the Rehostat is located in the housing too,up at the top. This can fail, but usually speeds 1-2-3 dont work, but 4 will. Pollen filter may be clogged if not clearing screen. Located centre of engine bay, just below windscreen(slide off black cover,2x spring clips).
    Headlamp fault could be the plug on the headlamp, or, the wiring inside from the plug to the bulb.
    Parking Lamp inop...are you moving the stalk up or down once `p`is selected on stalk? To select n/s or o/s parking lamps?
    Hope this helps !
    Alan.
    VW T6 150 DSG Camper £££
  3. Arrow Re: Lt 28 problems ???
    Jun 2010
    eastwood
    thanks mate, very useful info will have a poke and prod about see what haoppens and report back .
    incidently , i wasnt using the parking klight proper anyway it seems he he .
    whats the mpg on my lt28 i should achieve on a full tank travelling at a steady 70 pmh ? .. my mate reckons he does 550 miles to his tank ?
    we went cornwall and did a trip down there, and it was on fumes after only 330 odd ?
    ** the drivers side headlamp main beam has worked in the past too ? .. will look at connector **
  4. Re: Lt 28 problems ???
    Jun 2010
    eastwood
    right here goes ....
    cleaned contacts on headlamp plug and now headlamp working .
    however im having trouble locating the heater terminal plug im meant to waggle?
    however if i did find it and have waggled it and blasted with contact cleaner nothing happened. just want to make sure ive blasted and wangled the right thing
    can you supply me a pic where to find it?
  5. Re: Lt 28 problems ???
    Nov 2008
    20 Post(s)
    When you look at the heater blower unit under the bonnet, there is a fabric velcro cover over the whole unit. Peel this off the housing and you should see plug under the fan. Just next to battery tray level. 2 wires on the plug. There is nothing else down there so it should be easy to locate.
    Alan.
  6. Re: Lt 28 problems ???
    Jun 2010
    eastwood
    update :
    here goes :
    heater blower doesnt work on any setting .
    i have wiggled the wire to the blower. and it flew very briefly .
    then today briefly on position 1 on the ing, to my amazment fan blower started ? then died once van started
    would new bushes help my situation you think pleasE?
  7. Re: Lt 28 problems ???
    Nov 2008
    20 Post(s)
    It seems like the motor is faulty at the plug connection- common fault. I`d go for a motor rather than bushes unless you can rule out the connection being at fault.
    Alan.
  8. Re: Lt 28 problems ???
    Jun 2010
    eastwood
    ive removed the heater blower from the van .
    hooked on two wires to terminals then onto a car battery .
    heater/blower problermatic.. ie works then doesnt. i rotate by hand then to battery it works again
    could it be bushes?
    you say common fault motor faulty at terminal .. do i need to change the motor or terminal ?
    or bushes?
  9. Re: Lt 28 problems ???
    Nov 2008
    20 Post(s)
    Change the Motor, its all contained within it, so, just as easy. You may source some bushes for it and the fault could have been in the connection !
    Alan.
  1. 5 speed gearbox selector problems
    By firelizard in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2010, 02:51 AM
  2. TDI 1.6SE Coming/leaving home function + problems
    By garboy1 in forum Golf MK6 - 2009 - 2013
    Last Post: 03-12-2009, 03:05 PM
  3. Engine curring out on the motorway & other problems - please help!
    By oshy1981 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2009, 06:38 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. MK4 Golf V5 problems
    By hakysak in forum Golf MK4 - 1999 - 2004
    Last Post: 16-09-2007, 10:04 PM
