Thread: TDI Turbo Fault??
Results 1 to 8 of 8
  1. Unhappy TDI Turbo Fault??
    Mar 2006
    Whitehaven, Cumbria
    Hello,
    Just bought a 2003 TDI 130 saloon 97K miles yesterday after looking for the right one for 2 months. Imagine how disappointed I was when I pulled onto the motorway and the power dropped off at 3000 revs. This seems to happen in any gear. When I accelerate slowly above 3000 revs the turbo stops working all together. When the ignition is switched off for a while the turbo starts working again but with the 3000 rev limit.
    Please can anyone help, has anyone experiences a similar problem.
    Thanks.
    Jan 2006
    Nottingham
    Have the air mass meter checked first
    gellery Guest
    I have a similar fault on my 51 plate GTTDI, have had the MAF changed with no effect. Typically the car is fine for the first hour or so of driving and then if you try to accelerate there is no power. If I turn the engine off and on again it's fine for another half hour or so and it happens again.
    The car is now on it's 3rd visit to the garage and is having the turbo rebuilt. The garage has told me that it is a very common problem with the turbo that VW should have recalled and that reconditioning the turbo always fixes the problem. In the mean time im having to use a Toyota Starlet so I need to get the prob fixed ASAP!!!
    Does anyone else have experience of this problem?
    G
    Mar 2006
    Whitehaven, Cumbria
    Glynnd,
    Thanks for the reply. I haven't had this checked yet. Going to a local garage tomorrow to get the fault codes checked and hopefully this will reveal something. Having read a number of posts on this site I suspect / hope it is the air flow meter so I can get it fixed and start enjoying my new car.
    I’ll keep you posted.
    Thanks again.
    Mar 2006
    Whitehaven, Cumbria
    Hello,
    Got the ECU codes checked today and it seems to be the MAF meter. I have spoken to the dealer I bought the car from and he said the he would cover the cost of the repairs ( about £100 ). He has been surprisingly good about the problem, I would definitely recommend them.
    Speaking to the mechanic who checked my car he said the he has had a number of problems with the waste gate on VW turbos. Because it turns rather then lifts open if can sometimes jam with carbon deposits. The best thing to do in this case is to replace the turbo. Don’t know if this help anyone else but I though it best to post it up here anyway.
    Thanks.
    gellery Guest
    Ive had the waste gates replaced in the turbo and the turbo generally reconditioned, getting the car back on Friday. Apparantly the carbon traps around the notches in the waste gate and it jams open causing the engine to go into overboost.
    Proof is in the pudding though so i'll wait to see when I get it back!
    G
    Jan 2006
    Nottingham
    I suspect that I have this problem intermittently. Sometimes my car absolutely flies, I had a race with a clio 182 and he could not pull away from me it was a right laugh. But the performance has now gone back to normal again My car is a passat tdi 130!
    Mar 2006
    Whitehaven, Cumbria
    Well my air flow meter is fixed, hurray! I can now get above 3000 revs…
    …but not 4000. The guy at the garage seem quite knowlagable and he has suggested that it might be because the Exhaust Gas Recycle valve is carbonised. It will need stripped down and cleaned.
    Does this sound familiar to anyone???
    Thanks.
  1. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  2. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
  3. Abs Fault..... Please Help!!!
    By sels bora in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-04-2007, 08:54 AM
  4. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  5. 1997 Passat 1.8 non turbo rough idle fault
    By JHT in forum Passat - Archive Topics
    Last Post: 18-01-2007, 05:36 PM
