Thread: 2.0 Tdi 105 turbo failure
  1. 2.0 Tdi 105 turbo failure
    Sep 2009
    darlington
    Hi, i can buy a 55 plate passat 105 tdi, however the turbo has failed,suspect the oil pump to be the cause.
    Does anyone know if this engine will require the expensive balancer shaft kit like the 140 models do?
    Any advice on repair would be greatly appreciated
  2. Re: 2.0 Tdi 105 turbo failure
    DSG4ME Guest
    If it's a 105 it's a 1.9 PD mate, so it won't be turbo fail caused by oil pump, it mat hawever be simply turbo failure as they do fail, you could also check the vacumn hoses as a leak will cut the turbo out.
  3. Re: 2.0 Tdi 105 turbo failure
    Sep 2009
    darlington
    Hi,thanks for that info, the guy who is selling it said he had it in at main dealer who told him this is what it needed. Also on the logbook it says 105 but on the bootlid it says 2.0 tdi.
    Are they badged like that? Or maybe car has a story?
  4. Re: 2.0 Tdi 105 turbo failure
    DSG4ME Guest
    As far as I know, the 105 is a 1.9, and the 2.0 starts at 140 bhp, Skodas have less BHP iirc.
  5. Re: 2.0 Tdi 105 turbo failure
    May 2008
    The logbook often states power in kw, not bhp, therefore 103kw is the 140bhp 2.0 TDI.
  6. Re: 2.0 Tdi 105 turbo failure
    Sep 2009
    darlington
    Oh dear it looks like its the expensive repair job then.
    Is it not possible to repair the shaft where part has worn,or is there anywhere you can purchase ceaper parts? thanks
  1. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  2. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  3. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
