Thread: Central Brake Light
Results 1 to 10 of 11
  1. Central Brake Light
    Apr 2009
    ireland
    Hi Guys,
    Sorry if this is in the wrong section.
    Hi guys,
    I have a 2006 A6 2,0tdi estate. The central brake light has decided to call it a day / needs new bulbs. The manual tells me how to replace every bulb except that one. Before the dash warning "ping" drives me mad, does anyone know how to access this fitting. Is it a complete replacement unit or replace bulbs. Cant even see a way of accessing the unit.
    Any help would be much appreciated.
    Failing that, what wires do I cut to turn off that bloody "ping"??
    Thanks,
    Arderra.
  2. Re: Central Brake Light
    It is an LED unit and is replaceable as a whole unit.
    I need your email address to send you the details of how to remove the trim and release the unit. put a couple of spaces in the email address to avoid phishing.
    When you access the unit test to made sure you have 12V getting to the unit when the brake is pressed as this could be a broken wire in the hinge cable harness. Regards Peter
  3. Re: Central Brake Light
    Apr 2009
    ireland
    Quote Originally Posted by Peter D View Post
    Hi Peter PM sent
  4. Re: Central Brake Light
    I asked for your email address but you do not have enough posts to use the PM system. That is why I asked you to post it up with a couple of spaces in it. One you have the email from me you can edit your post and remove your address. Regards Peter
  5. Re: Central Brake Light
    Apr 2009
    ireland
    Sorry Peter
  6. Re: Central Brake Light
    Did you get the email or not. ?? Regards Peter
  7. Re: Central Brake Light
    Apr 2009
    ireland
    Hi Peter, Afraid not
    first letter in the email is zero. everything else seems fine.
    Arderra
  8. Re: Central Brake Light
    Apr 2009
    ireland
    Quote Originally Posted by arderra View Post
    Arderra
    Hi Peter,
    Got your message. Yes the email address is correct. Dont know why its not working!! Thanks for trying.
    Eoin
  9. Re: Central Brake Light
    The file may be to big for gmail so I have resent it in two parts.
    Regards Peter
  10. Re: Central Brake Light
    Apr 2009
    ireland
    Hi Peter,
    Dont worry about it. Emails just dont want to work. I'll use a lump hammer and BIG screwdriver to get it out lol
    Thanks for trying.
    Arderra
  1. Question Polo Brake Light Issue
    By rushdd in forum Polo - Derby - Lupo - Fox
    Last Post: 31-12-2010, 12:12 PM
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Polo brake light switch
    By mark smith1951 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-01-2008, 05:55 PM
